No Top End Power
Old May 14, 2008 | 05:19 PM
96GSRTeg197's Avatar
Default No Top End Power
Hey Guys,
I Have a 96 GS-R swap.
Just replaced the Stock Flywheel and the cluth that was in it with a Fidanza 7.5lb flywheel and exedy clutch.
First off, it feels like i have absolutely no power after 6500 rpm. used to be able to take my shifts all the way before redline and feel power till about 8000rpm but now i have to shift at about 7000rpm, My natural instinct kicks in and i just have to shift. Feels flat at 7000rpm just nothing there and doesnt sound like it will rev out any farther. Motor gets pretty loud as well. The motor is still running a really good compression so im pretty sure the motor isnt going south. Everyone told me when i got the 7.5lb flywheel that its gonna raise the top end power a little bit but so sure doesnt feel like it and i cant figure out why. Any ideas woould be helpful. Thanks
Also when we put the tranny back in some coolant got spilled and i think some got on the speedometer sensor because it doesnt work anymore ><. Would that fry the sensor?
V-tec is working as well.
Thanks guys
Modified by 96GSRTeg197 at 6:26 PM 5/14/2008
Old May 14, 2008 | 05:32 PM
ZE12O's Avatar
Default Re: No Top End Power (96GSRTeg197)
..what is top end?
are you talking about acceleration?
or torque hp?
Old May 14, 2008 | 09:38 PM
Default Re: No Top End Power (ZE12O)
Accel.
Old May 14, 2008 | 10:50 PM
Glove's Avatar
you absolutly sure vtec is coming on? what about the iab's?
Old May 15, 2008 | 03:27 AM
polishedturd's Avatar
I like PIE
no speedo=no vtec
lightweight flywheels FTL. put your stock back on and sell that piece of scrap metal.
Old May 15, 2008 | 04:18 AM
gibsanez's Avatar
Default Re: (polishedturd)
Lightweight flywheels don't "give" you horsepower
Old May 15, 2008 | 05:20 AM
I like PIE
Default Re: (gibsanez)
no sir, they dont.
just quicker revs:rollseyes:
and less torque:thumbsdown:
Old May 15, 2008 | 09:03 AM
Glove's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Lightweight flywheels don't "give" you horsepower</TD></TR></TABLE>
no, but they free up hp during accel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polishedturd &raquo;</TD></TR><TR><TD CLASS="quote">no sir, they dont.
and less torque:thumbsdown:</TD></TR></TABLE>
you dont lose any torque whatso ever.
the topic of flywheels has been beaten, and you guys are giving him wrong info on flywheels, it wasnt even his question to begin with.
Old May 15, 2008 | 09:24 AM
gibsanez's Avatar
Default Re: (Glove)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Glove &raquo;</TD></TR><TR><TD CLASS="quote">and you guys are giving him wrong info on flywheels, it wasnt even his question to begin with.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96GSRTeg197 &raquo;</TD></TR><TR><TD CLASS="quote">Everyone told me when i got the 7.5lb flywheel that its gonna raise the top end power a little bit but so sure doesnt feel like it and i cant figure out why. Any ideas woould be helpful. Thanks</TD></TR></TABLE>
Old May 15, 2008 | 07:03 PM
No speedo No v-tec?
Truth?
Pulled out my speedo sensor the gear is fine and the internal gear is fine. Just not registering to the gauge
And after further inspection my v-tec is not coming on which is why its being a turd.
Replaced the solenoid, nothing.
Re-checked the Wiring to the ECU, nothing.
Ran the codes came up with a 23 which is the pressure switch.
So no speedo no v-tec if there is truth to that then thats the place to start i suppose.
But where the problem with my speedo is i have no clue.
Old May 15, 2008 | 09:05 PM
goota's Avatar
its either broken, or the electrical wires to it are messed up somewhere.
Old May 15, 2008 | 09:09 PM
lazyvietboi's Avatar
fixing the speedo should do the trick.
Old May 15, 2008 | 09:54 PM
beatthisspeed69's Avatar
if speedo doesnt worc then vtec wont engaged found that out from personal experience so yea fix that and problem solved for the whole vtec thing..hope you get it worcin
96 EX
Jan 1, 2007 01:19 PM
The Hooligan
15
May 11, 2005 07:31 AM
ElectronBlueGsr1.8
Aug 3, 2004 08:10 PM
DOHCon15s
Oct 6, 2003 04:11 PM
