HELP!! P0131 Primary Heated Oxygen Sensor: Circuit Low Voltage
Old May 14, 2008 | 01:52 PM
SC61HB's Avatar
Default HELP!! P0131 Primary Heated Oxygen Sensor: Circuit Low Voltage
I am trying to pass emissions for my obd2 car and I keep throwing a code.
I am throwing: P0131 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low Voltage
I have checked the connection and it is fine. I have also tried another primary o2 and it still throws a check engine. What else do I need to check for or what could it possibly be??
Please help!!
Old Oct 11, 2008 | 07:47 AM
crazy-ej8's Avatar
Default Re: HELP!! P0131 Primary Heated Oxygen Sensor: Circuit Low Voltage (SC61HB)
i am having the same problem as this. has anyone come across it and how was it fixed?
Old Oct 11, 2008 | 07:55 AM
Former User's Avatar
Default Re: HELP!! P0131 Primary Heated Oxygen Sensor: Circuit Low Voltage (crazy-ej8)
Is fuse 15 blown? If so, look into the common short circuit problem of 6th generation Civics:
http://www.tegger.com/hondafaq...e.pdf
If the O2 sensor and its wiring are fine, then check the corresponding terminals at the ECU. If they too are fine, then you may have an ECU problem.
Modified by RonJ@HT at 11:03 AM 10/11/2008
papi123
Honda Civic (2001 - 2005)
Apr 25, 2014 09:07 PM
skaternak
Jul 10, 2008 07:46 PM
omil2374
Oct 17, 2006 12:30 PM
crxtreme27
Sep 19, 2002 02:01 PM
scrubachu
Jul 30, 2001 04:24 AM
