Intermediate Shaft question
The one thats on there, the bracket was welded but the weld broke. A shop said they couldn't fix it because of the type of metal it was. What other ways of making a bracket are there?
yeah either the metal is too thick, cuz it should be and he had a regular muffer shop welder, or it was alluminum, i believe 96 and newer were aluminum and older were steel, probably want steel or find someone to weld alluminum.
Yeah welding cast iron can be tricky from what I hear.
I've made a few ATTS adapter plates to use the standard intermediate shaft with SH blocks. No welding required and have been proven to be pretty stout.
PM me if you're interested.
I've thought about that too but it takes a lot of material and if you make it out of steel it's heavy and takes forever to machine. If you make it out of aluminum it cuts fast and can be done in 3 operations. But a piece of aluminum that large add a bunch of extra money into the equation so I chose to make a simple and effective steel adapter plate.
If you charge $250 for a simple bracket no one will ever buy it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludecz »</TD></TR><TR><TD CLASS="quote">Our fabricator made custom halfshaft bracket for our customer with SH block.
No adapter plate is needed. I'll get some pictures and prices.
that would be awesome if u can get those pics. Thanks
I think the best would be stick with h22A intermediate shaft so you can use stock axle. We just did this mix up with different parts as that was all we could find laying around at the shop. We will have this SH block for like one more week. If there would be some interest I would give our fabricator mine h22 halfshaft to make one or more units for SH with non ATTS tranny like M2a4.
im in need of one of these adaptors so i can start my swap. pirate if you could contact me id really appriciate it. my e-mail is hounesr@sbcglobal.net thanks
integrawow
May 26, 2007 07:46 AM
