STRAIGHT PIPED EJ6 RUNNING RICH....
Old May 14, 2008 | 10:08 AM
'96typeR's Avatar
Default STRAIGHT PIPED EJ6 RUNNING RICH....
i have a ex header without a cat on my 96 ek, and only one o2 sensor is plugged in and its running rich, if i have my other o2 sensor welded somewhere on the piping would it run normal without a cat?? or would it still throw off the ecu??
Old May 14, 2008 | 10:40 AM
obuhmyuh's Avatar
Default Re: STRAIGHT PIPED EJ6 RUNNING RICH.... ('96typeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’96typeR &raquo;</TD></TR><TR><TD CLASS="quote">i have a ex header without a cat on my 96 ek, and only one o2 sensor is plugged in and its running rich, if i have my other o2 sensor welded somewhere on the piping would it run normal without a cat?? or would it still throw off the ecu??</TD></TR></TABLE>
cat or no cat shouldn't matter, its however much fuel your ecu is telling ur injectors to spit out. if the o2 sensor isn't sending out the right signal your car will run rich/lean. so yes, you need to get that o2 sensor installed for ur car to not run AS rich.
Old May 14, 2008 | 10:46 AM
'96typeR's Avatar
Default Re: STRAIGHT PIPED EJ6 RUNNING RICH.... (obuhmyuh)
so if i get the other o2 sensor on there it'll run normal again(yes or no question)? thanks!!
Old May 14, 2008 | 10:49 AM
obuhmyuh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’96typeR &raquo;</TD></TR><TR><TD CLASS="quote">so if i get the other o2 sensor on there it'll run normal again(yes or no question)? thanks!!</TD></TR></TABLE>
in short, yes. IT SHOULD run the way it was meant to be ran (w/2 o2's) but if something else is causing it to run rich ur gonna have to fix that too.
team_exceed's Avatar
lamens terms... yes
Old May 14, 2008 | 10:59 AM
'96typeR's Avatar
alright coo, thanks!!
beastman@
Jul 17, 2008 12:44 PM
pizzamanprelude
Aug 2, 2006 03:26 PM
crackerjacker006
11
Dec 17, 2004 12:38 PM
Team 4R
Feb 3, 2004 04:45 AM
spencedogg
27
Nov 20, 2003 04:20 PM
