vtec not workin
Old May 14, 2008 | 07:16 AM
t-dizzy's Avatar
Default vtec not workin
i have a 92 vx hatch with the d16z6 and p28 ecu it is a swap but vtec is not workin and hav no ida what it could be
Old May 14, 2008 | 08:29 AM
chimmike's Avatar
Default Re: vtec not workin (t-dizzy)
i'm sorry, but how do you expect us to help you with as little info as you've given us?
Old May 14, 2008 | 08:38 AM
t-dizzy's Avatar
Default Re: vtec not workin (chimmike)
well i dont even know where to start what should i be checking
Old May 14, 2008 | 11:33 AM
cdnav8r's Avatar
There are a few things that can cause this. If the VSS (vehicle speed sensor) on the transmission is not working you will not be able to use VTEC - you should also get a CEL for that. If the engine temp probe fails you will also not get VTEC as it requires 155 degrees to allow it to operate.
The more info you can post the better people can help :-)
Good luck
Old May 15, 2008 | 06:56 AM
t-dizzy's Avatar
Default Re: vtec not workin (cdnav8r)
so what your sayin if my speedo works then my sensor should be ok right?
Old May 15, 2008 | 07:03 AM
h22civic88's Avatar
Could be speedo, could be your coolant temp sensor isnt reaching operating temp, and also try cleaning your vtec solenoid... I've had an issue as simple as that, and cleaning it out fixed the issue!
Old May 15, 2008 | 07:30 AM
t-dizzy's Avatar
Default Re: vtec not workin (h22civic88)
WHATS THE PROPER NAME FOR VTEC SOLENOID
Old May 15, 2008 | 07:33 AM
h22civic88's Avatar
? VTEC solenoid? Thats it... Its a solenoid and it controls when it allows oil pressure to engage vtec.... ?
Old May 15, 2008 | 08:51 AM
ddd4114's Avatar
It's called the "Spool Valve" on Majestic Honda. Most people just call it the "VTEC solenoid".
Old May 18, 2008 | 01:44 PM
raybrig100's Avatar
Check your oil level, oil pressure. Low or no oil means no VTEC.
natesfresh
12
Oct 28, 2008 10:18 AM
ricearoni56
Feb 8, 2008 09:31 AM
HONDRETTI
Nov 19, 2007 06:33 PM
EKhothatch
Sep 2, 2005 09:08 AM
jdmwidebody094
11
Sep 4, 2003 03:04 AM
