Vibrations from 60 and up? Yes wheels are balanced.
Old May 14, 2008 | 07:02 AM
Ser1N's Avatar
Default Vibrations from 60 and up? Yes wheels are balanced.
Ok so heres the story im stumped right now.
Friday- Car runs fine no vibrations at any speed
Saturday- Replace from rotors and pads with brand new ones, I go up to 60+ and feel alot of vibration. So at this point I already know my tires are bad and think maybe it time for new ones cause they might be unbalanced.
tuesday- buy new tires get them balanced and mounted all that deal, the vibration is still happening but this time the vibrations seem to wave from the front to the back then move from the back to the front again. very odd.
Is there any possibility this could be a result of a faulty rotor? It cant be the wheels at this point, but now i dont know what else to look for. It does it most at 70+ tho but u can feel a little starting at 60.
Old May 14, 2008 | 07:08 AM
HondamanXxX's Avatar
GO GIANTS!
Default Re: Vibrations from 60 and up? Yes wheels are balanced. (Ser1N)
Maybe you didn't torque the wheels properly.
Old May 14, 2008 | 07:22 AM
Ser1N's Avatar
Default Re: Vibrations from 60 and up? Yes wheels are balanced. (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you didn't torque the wheels properly. </TD></TR></TABLE>
That i made sure was right multiple times. This happens even after the shop changed to my new tires.
Old May 14, 2008 | 08:08 AM
moores55's Avatar
Rotors might be shot.
Old May 14, 2008 | 08:28 AM
chimmike's Avatar
Default Re: Vibrations from 60 and up? Yes wheels are balanced. (moores55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moores55 &raquo;</TD></TR><TR><TD CLASS="quote">Rotors might be shot. </TD></TR></TABLE>
that's not going to cause off-brakes vibration.
Are your wheels hub-centric or lug-centric? This can make a big difference.
Old May 14, 2008 | 09:28 AM
Ser1N's Avatar
Default Re: Vibrations from 60 and up? Yes wheels are balanced. (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">
Are your wheels hub-centric or lug-centric? This can make a big difference.</TD></TR></TABLE>
I think they are hub-centric? (GT3s)
Its just really odd cause 1 hour before i changed the rotors it was fine then i changed them and it was bad. Nothing fell off thats for sure. I guess im still stuck in the (it must be the rotors) deal. Ill change them out with new ones soon just to get that outta the way. I just keep getting "it cant be the rotors" but you know .
Old May 14, 2008 | 09:40 AM
chimmike's Avatar
if they're hub-centric, you need that little piece of plastic that centers the wheel on the hub, if not you risk vibration.
I've got hub centrics now without the plastic and I don't get vibration, but that could change at any time.
Old May 14, 2008 | 09:51 AM
Ser1N's Avatar
The center cap that people steal from our wheels most of the time?
its like feather weight.
Old May 14, 2008 | 09:56 AM
chimmike's Avatar
no, not the center cap. It's a plastic ring that you put on the hub before you install the wheel. It keeps the wheel perfectly centered on the hub.
Old May 14, 2008 | 09:59 AM
Ser1N's Avatar
Oh shoot, i dont think i have ever had any of them on my car.
Do you know where i can order them from ? or the name of them?
I think that is what i need.
Old May 14, 2008 | 08:40 PM
Ser1N's Avatar
oh man i got the hub centric rings from discount tire and damn they just bent and broke, Does anyone know where i can order some metal or good ones ? 73x56.15mm? 98 civic DX
Old May 14, 2008 | 09:24 PM
BlackDeuceCoupe's Avatar
HT White Ops
that's not going to cause off-brakes vibration.</TD></TR></TABLE>
Disc brakes are NEVER off! The pads are always dragging on the rotor...
Old May 15, 2008 | 07:48 AM
moores55's Avatar
Default Re: Vibrations from 60 and up? Yes wheels are balanced. (BlackDeuceCoupe)
I have warped mine and it would shake even when i was not breaking. Pads are always touching.
Old May 15, 2008 | 07:51 AM
chimmike's Avatar
I've been in cars where we deliberately super-heated the rotors, then pressed the pad into 'em hard to indent them, and kept driving without vibration. The only time we got the vibration with warped rotors was on braking.
Old May 15, 2008 | 07:53 AM
del_slow420's Avatar
best bet would be to get a dial indicator and check your run out of your rotors will tell you if there warped or not..
Old May 15, 2008 | 08:58 AM
Ser1N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">I've been in cars where we deliberately super-heated the rotors, then pressed the pad into 'em hard to indent them, and kept driving without vibration. The only time we got the vibration with warped rotors was on braking.
Your right on the mark with the hub centric ring, your 100% correct. I finally found a place to order the one i need online.
Thanks for the help guys
masospaghetti
Jun 7, 2016 09:44 AM
iceman7329
Nov 15, 2006 04:38 PM
mikeunreal2
24
Jul 23, 2006 08:35 AM
jmpgraphy
Apr 30, 2006 10:21 AM
thomst4R
Suspension & Brakes
Jun 27, 2005 11:13 AM
