What's the difference between the Integra Type R(b18c5) 97 and below vs the 98 and above????
Old Jul 14, 2002 | 07:02 PM
p0oty's Avatar
Default What's the difference between the Integra Type R(b18c5) 97 and below vs the 98 and above????
I want to buy the b18c5, but is the 98+ R engine that much better? What EXACTLY is different? Gearing? Cams? Compression? Give me the details.
Also, when did they start making the Type R? 96?
Old Jul 14, 2002 | 07:07 PM
poison's Avatar
Default Re: What's the difference between the Integra Type R(b18c5) 97 and below vs the 98 and above???? (p0
also i believe 97 and down has 4x114.3 lug, and 98+ has 5x114.3
Old Jul 14, 2002 | 07:10 PM
six_speed's Avatar
B18C5 USDM 97-98,
00-01 Integra Type-R 195 hp @ 8000 130lb-ft @ 7500 1797cc
DOHC VTEC
10.6:1 c.r.
S80
(Helical LSD)
00+ itr cams is upgrade to ctr spec...so 00 Itr engine is better then 97,98.
check out this cam specpage thingyamjic
http://forums.clubsi.com/showflat.ph...b=5&o=0&fpart=
Old Jul 14, 2002 | 07:35 PM
poison's Avatar
id go with the newer motor
JDM_rolex
Dec 6, 2014 09:01 AM
Havokmkr
Apr 21, 2003 06:24 PM
It's James
Jan 9, 2003 08:28 AM
HX_Guy
Jan 17, 2002 05:44 PM
oneovakindpnoy
Aug 14, 2001 09:30 PM
