Bigger bore = More HP??
Im sure everyone on this board has seen that by running larger pistons/bigger bore, you can make alot more HP running NA. Ive seen 81mm sleeved blocks making around 200-210HP, and 84mm sleeved block making 210-240HP. My question is, if larger sleeved blocks really making more HP, why doent anyone resleeve their blocks to the largest possible mm a Bseries block can take? I heard B series blocks can take up to 87mm sleeves. Why doesnt anyone go with that? Just wondering..........
It's like choosing between 12.5:1 compression and 11.0:1. You know that the first one will give you more power, but what you give up is drivabilitly.
An 87mm bore sounds like it would be a race only idea. A drag race only type thing..most people on this board are into road racing. Although, I don't know exactly what a 87mm bore would do in a road racing situation, I assume that it wouldn't be the best thing
that's right, just like you can spend same amount of money to get a turbo R and makes more power than a N/A R, but not everyone doing that.
I see the main reason that most ppl don't resleeve blocks is because it would mean doing engine mods and not just your basic bolt-on. Many people would feel initimidated when doing actual internal modifications to an already great engine. There are a lot more variables when dealing with internal engine mods compared to bolt-on mods.
87mm sleeves on a B series motor is not recommended for daily drivers. The larger you go on the bore, the thinner the walls get between the pistons. If you look at a block, there isnt much metal between the pistons. 84-85mm is the largest i would ever consider on a daily driven car. Any larger and you risk having sealing problems between the head and block.
Also many people do not go bigger bore due to the significant cost that is involved from custom pistons, resleeving, etc...
Cheapest route is B20 block with custom pistons. You get the 84mm bore without the huge expense.
What about the new Dart/Payn Block that is coming out soon. I don't know the details but Dart as in Dart Heads, of small block& big block domestic fame has teamed up with import tuner/eng Payn Technologies to produce a new B-series block. Here are the specs: http://www.payntechnologies.com/hondablock.html
Mattj
Mattj
7rrivera7
Dec 28, 2006 06:07 AM
