shock mount help
Old May 13, 2008 | 03:23 PM
01ethansh's Avatar
Default shock mount help
ok guys i have a 90 dx hatch and ive been notcing that its louder in the back so i jack it up and where the shock unit mounts to the (i guess rear trailing arm) on both sides the bolts are broke and barely hangin on...i have crx coilovers which are really low even set all the way up, could this b the reason....?
Old May 13, 2008 | 03:45 PM
grog's Avatar
Default Re: shock mount help (01ethansh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01ethansh &raquo;</TD></TR><TR><TD CLASS="quote"> where the shock unit mounts to the (i guess rear trailing arm) on both sides the bolts are broke and barely hangin on...i have crx coilovers which are really low even set all the way up, could this b the reason....?</TD></TR></TABLE>
I dont know if that is reason you car is so low. did you put the suspension on? what is on there?
make sure to replace that flange bolt with the correct bolt from honda or a grade 8 or what ever it calls for.
CrxChicken
Aug 6, 2013 10:38 AM
baonest
May 10, 2007 04:47 AM
huntarrr
Aug 17, 2006 09:47 AM
xfrankx
Jul 3, 2006 07:15 PM
c1v1c98
Sep 24, 2003 02:24 AM
