Clunking from right rear shock...
Old Sep 23, 2003 | 02:51 PM
c1v1c98's Avatar
Default Clunking from right rear shock...
This is on a 98 EX. I installed my Tein S-Tech and KYB AGX combo about 4 days ago and yesterday I noticed a rattle, almost like a clunking, but not really, coming from my right rear shock. Its only when I hit rough bumps. Could this be caused by the Cap bolt not being on tight enough? It looks like it might have loosened itself a thread and a half or so. I can get that thing any tighter, or even loosen it for that matter. I'm pretty sure the lower bolt that holds the shock on or the lower control arm bolt are nice and tight. Any help would be much appreciated. Thanks..
Old Sep 23, 2003 | 02:54 PM
Katman's Avatar
Default Re: Clunking from right rear shock... (c1v1c98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1v1c98 &raquo;</TD></TR><TR><TD CLASS="quote">Could this be caused by the Cap bolt not being on tight enough? I can get that thing any tighter, or even loosen it for that matter. Any help would be much appreciated. Thanks..</TD></TR></TABLE>
yes that could be one reason.
Another could be that if you have TEIN pillowball mounts, you might wanna check to see if something is loose inside the balljoint area of the pillowball mount.
Double check to see that all rear suspension bolts are tightened down..maybe you missed a bolt..
Old Sep 23, 2003 | 02:58 PM
c1v1c98's Avatar
Default Re: Clunking from right rear shock... (Katman)
I don't have tein pillow ball mounts. And im pretty sure all the bolts that I removed are tightened. I thinks its the cap bolt. Any Ideas on how to tighten the damn thing more? By the way, thanks for the reply.
Old Sep 24, 2003 | 02:24 AM
c1v1c98's Avatar
Bump
wes_foll_99si
Apr 16, 2010 03:36 PM
sloweh3
10
Jan 4, 2008 06:31 PM
2Point2EH2
Apr 25, 2006 10:36 PM
onemoreday21
Jul 2, 2005 08:55 PM
Campee
31
Nov 19, 2003 03:19 PM
