crankshaft pulley bolt
Old May 13, 2008 | 01:16 PM
95silverluder's Avatar
Default crankshaft pulley bolt
I'm trying to replace my timing belt/water pump, and I cant get the crankshaft pulley bolt to break lose and i've tried everything from nut buster to a huge *** impact and nothing seems to work so if someone could give me some tricks or help it would be amazing. Thanks in advance.
Old May 13, 2008 | 01:27 PM
Default Re: crankshaft pulley bolt (95silverluder)
bump
Old May 13, 2008 | 01:44 PM
saikou's Avatar
There is no need to bump your thread so soon, give it some time.
If you would have searched, you could have easily realized that a crank pulley holder and 1/2" tools would work wonders.
Edit:
Well, it seems the search engine isn't working.
Old May 13, 2008 | 01:47 PM
Default Re: (saikou)
no **** thats why i asked
Old May 13, 2008 | 01:51 PM
Default Re: (95silverluder)
and I have the crank pulley holder, I mean i've tried everything here and the stupid thing won't budge. I've been trying to get it off now for 3 days, getting nowhere and running out of options.
Old May 13, 2008 | 02:03 PM
saikou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95silverluder &raquo;</TD></TR><TR><TD CLASS="quote">no **** thats why i asked</TD></TR></TABLE>
I'm sorry.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95silverluder &raquo;</TD></TR><TR><TD CLASS="quote">and I have the crank pulley holder, I mean i've tried everything here and the stupid thing won't budge. I've been trying to get it off now for 3 days, getting nowhere and running out of options.</TD></TR></TABLE>
I'm assuming you've soaked the bolt in PB Blaster/WD-40. I had no trouble at all with the above said crank pulley holder and 1/2" breaker bar & attachments w/ cheater pipe. Shouldn't be giving you much trouble.
Old May 13, 2008 | 02:09 PM
Yeah its drenched its nut buster....I just don't know what else to do.
Old May 13, 2008 | 02:18 PM
Eddiebx's Avatar
if you have the crank pulley holder tool, then there's on excuse for not being able to get the nut off, besides being too weak,
Old May 13, 2008 | 02:31 PM
Default Re: (Eddiebx)
I have three people pulling on it, i've kicked it while someone was holding it, I've tried almost everything, IT WILL NOT BUDGE!!!!
Old May 13, 2008 | 02:33 PM
h23on17s's Avatar
haha keep at it... itll give eventually... just be carefull not to round the bolt off =P
Old May 13, 2008 | 02:37 PM
Default Re: (h23on17s)
:fingers crossed: I'll just keep giving it hell until it finally gives in. Thanks
Old May 13, 2008 | 02:52 PM
viper_boy403's Avatar
I had to use a 3 foot breaker bar to get mine off lol. Even air tools weren't working.
Old May 13, 2008 | 05:55 PM
gstrudler's Avatar
Default Re: (viper_boy403)
If your car is on the ground (like mine was), I used a 2' 1/2" drive extension to get the breaker bar outside the car. With the other bar with the pulley holder wedged into the ground, it broke loose, but it was a pita before that; I thought I was going to break my Snap-On breaker bar.
Old May 13, 2008 | 06:35 PM
esedulerp5tenin's Avatar
Default Re: (gstrudler)
put the car on the ground, both front wheels on, and turn the wheels to the left so you can get the extension in there.
crank pulley holder + 1/2" breaker bar braced against the ground.
19mm socket + 2' extension to clear the fender + another 1/2" breaker bar + 6 foot steel pipe from home depot.
got it off myself. (insert sexual innuendo here)
socialistic
31
Jun 26, 2011 12:54 PM
model x
Sep 30, 2006 09:38 PM
freshley
Jun 26, 2006 01:19 PM
Yolandita
May 21, 2006 06:54 PM
thrty8street
19
Feb 20, 2005 07:52 PM
