Need help on 94 integra hood
hi eveyone, I am having a hard time closing my hood. I guess this usually happens for much older cars, because my EG had the same problem. So, I have a 94 integra and hood would not close, slamming it won't help. Did anybody have this problem before? Any help would be useful, thanks.
my hood has something similar to that. When I pull the hood relase, the cable gets stuck and does not return back to its normal position. It stays in the open position.
For mine, it is the spring that resets the cable after you pull it to open the hood. It is kind of hard to explain, but if you are looking at the latch, you can see the spring. Use a scredriver and push the spring down. That will pull the cable back.
brcivic411
Apr 9, 2002 07:06 AM
