B16 Head - Bowl Diameter - 81mm
Hey, what this the "bore" diameter of the a B16A head (combustion) chamber - does it match up to the 81mm bore of the block (including the quench)? What about a a GSR - the quench is the head.....
Will the experts "chime in"
Another way to ask the question
On a K20 does the bore of combustion chamber (head) match up with bore of block - experts can comment on quench etc.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">Are you refering to a B20/vtec?</TD></TR></TABLE>
Yes and also comment on B16, GSR and K20
QUOTE=all-mtr-teg]Aren't OEM HG good up to 82mm bore also? [/QUOTE]
What does HG stand for?
OK =Head Gasket !
Modified by Johnny_9 at 1:30 AM 5/14/2008
Modified by Johnny_9 at 3:20 AM 5/15/2008
OK =Head Gasket !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">It should be 81mm or a bit smaller. You don't want the combustion chamber bore larger than your HG bore or your block bore.</TD></TR></TABLE>
Can u comment on the GSR block, pistons & head - GSR head is flat - the quench pad is the head (c.f. with the B16B head) - the combustion chamber ("CC") bore diameter is looks much smaller than the block bore, but I guess you have to look at the pistons, right?
B20B Engines - how good his the squish, if the head isnt matched to the bore?
Modified by Johnny_9 at 1:08 AM 5/15/2008
93B18
Oct 3, 2001 08:22 PM
