vtec solenoid wire voltage
Old Jul 14, 2002 | 04:38 PM
r7's Avatar
r7
Default vtec solenoid wire voltage
what do you guys get for a voltage reading from the vtec solenoid wire? when the key is ON but not running, and what do you get as a reading when the car is running
please, i need answers from all different bseries motors, and different ecu's, hopefully a few 1st gen (pr3 's ) as well!
Old Jul 14, 2002 | 08:49 PM
tinkerbell's Avatar
Default Re: vtec solenoid wire voltage (r7)
ive not tested this in practce but here is the theory:
what do you guys get for a voltage reading from the vtec solenoid wire when the key is ON but not running? 0v and what do you get as a reading when the car is running 0v
when vtec engages i think it would be 12v (or maybe 5v)
why do you ask?
anyone gone out to measure this 'live'?
hth,
t..
[Modified by tinkerbell, 3:50 PM 7/15/2002]
Old Jul 14, 2002 | 09:40 PM
Kamin's Avatar
Default Re: vtec solenoid wire voltage (tinkerbell)
its 12v when vtec is engaged
when the car is on or idling or anything below the vtec engagment it should be 0 volts.
to test the solenoid, disconnect the 1pin connector (green maybe? its the one with 1 wire inside)
touch a wire to the pos. terminal on the battery, then the solenoid side of the green connector.
it should click. if it does the solenoid is fine.
[Modified by KAMiN, 10:41 PM 7/14/2002]
Old Jul 14, 2002 | 09:44 PM
tinkerbell's Avatar
Default Re: vtec solenoid wire voltage (KAMiN)
PS the solenoid must remain grounded when doing this test above,
ie the metal body of the solenoid needs to be touching the chassis/engine or 'earth'
(just thought i'd clarfiy your good comments KAMiN )
t..
Old Jul 14, 2002 | 10:07 PM
Kamin's Avatar
Old Jul 14, 2002 | 10:22 PM
r7's Avatar
r7
what voltage should you get from the green wire? not solenoid side
i get 10volts when the key is ON, motor not running
is this right?
and when the car is running (idle) it is 12v...
the ecu is a pr3
[Modified by r7, 7:23 AM 7/15/2002]
Old Jul 14, 2002 | 10:59 PM
tinkerbell's Avatar
what green wire?
on the ECU?
what does it attach to?
t..
Old Jul 15, 2002 | 12:07 PM
r7's Avatar
r7
yeah to the ecu.. the vtec solenoid single wire.. goes straight to the ecu
thats the one im talking about
Old Jul 24, 2002 | 04:54 PM
r7's Avatar
r7
anyone?
94whitegsi
Sep 26, 2006 01:28 PM
05 S2K Stoner
Oct 28, 2004 06:40 AM
mr. carpenter
May 5, 2004 09:47 PM
