Need help..................HID ballast question
Old Jul 14, 2002 | 04:33 PM
STC's Avatar
STC
Default Need help..................HID ballast question
Are the ballast waterproof? Thanks.
Old Jul 14, 2002 | 04:34 PM
migs's Avatar
Default Re: Need help..................HID ballast question (STC)
I would guess they are water resistant, versus water proof.
Old Jul 14, 2002 | 04:39 PM
machgo5go's Avatar
Default Re: Need help..................HID ballast question (MiGs)
Anybody experienced the new SPW's Hid kit with Hella ballast retails for $599.00 for 9006s?
Kit looks well put together with harness which also connects to battery directs.
Old Jul 14, 2002 | 05:58 PM
JohnnyBoy's Avatar
Default Re: Need help..................HID ballast question (machgo5go)
Most are as they are designed to be in an engine bay....
Old Jul 14, 2002 | 06:00 PM
migs's Avatar
SPW kits? Do they have a wire attached to the bulb, or is it seperated?
Old Jul 14, 2002 | 06:04 PM
machgo5go's Avatar
It separated. Plugs into harness to ballast.
Old Jul 14, 2002 | 06:05 PM
STC's Avatar
STC
Default Re: Need help..................HID ballast question (JohnnyBoy)
Thanks. I got the Phillips kit, so I hope they are water-resistant.
Old Jul 14, 2002 | 06:33 PM
pleiades nutz's Avatar
If you purchased them in the group buy through visual dynamics they are warrantied. Im sure they are designed to be water resistant, you should avoid direct contact with large amounts of water if anything.
Fo-Do Fanatic
Lighting
20
Jun 15, 2009 09:56 PM
Importn2oRacer
Lighting
May 17, 2008 01:06 PM
johnsaccord
Mar 13, 2003 01:16 PM
k_spek
Oct 21, 2002 06:31 PM
