hid install question
92-95 civic guys with hids, where and how did you mount your hid ballasts? I just got my hella hid kit and was looking for suggestions on where exactly to mount the ballasts.
One more question. The whole kit is plug n play, but with the kit, i bougt you have to pin the terminals into the connector that plugs into the stock harness. I just need to know which terminal is for the low beam, high beam, and ground on the stock headlight harness connector.
The terminals are arranged like this on the stock headlight harness connector when you look straight at it.
l l
I just need to know what the left, right, and upper terminals are, so i can pin the hid connector that plugs into the stock harness with the correct terminals. Sorry if this is a dumb question but i tried searching and couldn't find anything. Thx for any help.
[Modified by laugHin22CX, 10:32 AM 10/20/2002]
l l
Re: hid install question (laugHin22CX)
get a volt tester, and stick it in each prong..find it that way....I need to know the same thing with my kit. If you find out, let me know
Problem is, I have no wiring harness right now so I have no voltage to test. lol.
Good luck.
You might be able to find out from looking at a wiring diagram, if you can find one.
Good luck.
Re: hid install question (hot_EG)
I took your advise hot_EG and borrowed my friends volt tester and this is what i found out:
When looking straight at the connector on the stock headlight harness from the front of the car,
the right prong is the ground,
the upper prong is for the low beam,
and the left prong is for the high beam.
Hope this helps. Now i just need to figure out where i'm gonna mount the ballasts.
Vtec195hpR
01-18-2003 02:43 PM
