crank senser location?
Old May 12, 2008 | 06:33 PM
dcCale's Avatar
Default crank senser location?
i have a 2001 gsr, with a b18c jdm motor, and i was wondering where the crank senser is located on that motor. Does anyone know i need help to get this car started.
Old May 12, 2008 | 06:37 PM
lmike6453's Avatar
crank fluctuation sensor? right next to the oil pump underneath timing belt cover
Old May 12, 2008 | 06:41 PM
dcCale's Avatar
yeah that sensor. So do i have to take the timming cover off then to see it
Old May 12, 2008 | 06:48 PM
lmike6453's Avatar
yes the lower one...i just threw a code for it last week...check it out...
https://honda-tech.com/zerothread?id=2291562
Old May 12, 2008 | 06:52 PM
dcCale's Avatar
would that make my injectors not open?
Old May 12, 2008 | 07:03 PM
lmike6453's Avatar
no...car will run with #54 cel..just runs like crap if you pay close attention...
Old May 12, 2008 | 07:12 PM
dcCale's Avatar
what would make my injectors not open? the only codes i have is crank senseor and knock sensor. My injectors wont open tho what could it be?
Old May 13, 2008 | 07:26 AM
lmike6453's Avatar
did you have them tested off the car? spray pattern doesn't spray?
i'd say to reseat them
Old May 15, 2008 | 05:17 AM
dcCale's Avatar
i did take them out and have them cleaned and still nothing.I also used a noid light to check if they are even getting signal and they are not. I have switched out my ecu and used 2 other ones. What else could do this?
Old May 15, 2008 | 07:27 PM
lmike6453's Avatar
wow so the electrical is messed up...i guess make sure that your injecters are compatible with your ecu-don't now that much if obd2 is compatible with obd1...
tougeem2
Nov 15, 2011 05:39 AM
kndj30
Honda Civic (2001 - 2005)
Feb 11, 2010 03:58 AM
2000siturboR
Nov 6, 2009 03:29 PM
ITR.#1446
Nov 1, 2009 12:47 PM
j_torres707
Mar 28, 2007 08:48 PM
