what cams would you recommend?
Old May 12, 2008 | 05:31 PM
Mikej425's Avatar
Default what cams would you recommend?
I have a b20b with a gsr head, titanium valves springs and retainers and i was wondering what the best aftermarket cams would be?
also suggestions for intake manifolds and header would be appreciated.
Old May 12, 2008 | 11:33 PM
KENetics1's Avatar
Default Re: what cams would you recommend? (Mikej425)
none, switch out stock b20 pistons first
Old May 13, 2008 | 05:40 AM
riceburner700's Avatar
Default Re: what cams would you recommend? (KENetics1)
what are your goals? N/A or some sort of F/I
Old May 13, 2008 | 09:36 AM
Mikej425's Avatar
I have some b20 high compression pistons and apr head studs and bolts but I haven't put em in yet
Old May 13, 2008 | 02:12 PM
vtecb18c's Avatar
i have toda vtec killers in my gsr bubble...ridiculous
Old May 13, 2008 | 06:56 PM
Mikej425's Avatar
Default Re: what cams would you recommend? (vtecb18c)
yeah those cams are insane, just saw some youtube footage of em but this is kind of a daily driver that i want to make faster and those vtec killer cams are for dragracing
but i appreciate the help anyways. if you have any other suggestions please let me know.
Old May 13, 2008 | 11:26 PM
KENetics1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikej425 &raquo;</TD></TR><TR><TD CLASS="quote">I have some b20 high compression pistons and apr head studs and bolts but I haven't put em in yet</TD></TR></TABLE>
what is the compression of the pistons you have?
Old May 14, 2008 | 05:21 AM
Mikej425's Avatar
They're just the stock b20b pistons so im not sure of the actual compression but the guy I bought it from gave me some high compression pistons and rods he got off ebay but im not sure how much better those would be. I don't know much about compression and cams and what not but I know a little
Old May 14, 2008 | 09:17 AM
KENetics1's Avatar
did he tell you brand or part no. of the high compression pistons? are they cast or forged?
Old May 14, 2008 | 10:07 AM
vtecb18c's Avatar
their not to bad on the street. a little bit of a rough idle but a little revs to get you going is all it takes..if your looking for a street ap, i heard nothing but good things from crower and jun s2 cams..let me know on what you decide cause i can never have enough input for my next project
**as far as mani'z i have a vivid magnus race on mine but i also know someone who has it on there street/drag crx and as far as mid and high range, their crazy..but theres always s2 pro series which is what i used to have and that made good power all through the range
Modified by vtecb18c at 11:13 AM 5/14/2008
Old May 14, 2008 | 10:38 AM
Mikej425's Avatar
He didn't say what brand they were. And I think they're forged but idk
And I appreciate all the help and info guys. I will probably go with skunk2 cams or crower depending on the price difference. I couldn't stand the idle with the vtec killer cams. And I will probably get skunk2 IM but I was wondering about edlebrock victoryx mani's (I think that's the name) if anybody has experience with em plz help
Old May 14, 2008 | 10:41 AM
vtecb18c's Avatar
mike if your going to go with s2 everything, stick with the pro series mani from s2...i believe in matching all your head parts with the same manufacturer...they never use other peoples products when their testing for power so you cant go wrong
Old May 14, 2008 | 05:27 PM
Jdm_jay's Avatar
you can use stock itr cams. or even find a stock ctr intake cam and itr exhuast cam. the ctr cam has 3 degrees more then an itr cam on the intake side of the vtec lobe.
Tinoo
16
Aug 29, 2013 09:11 AM
GoCarInteg
Sep 7, 2005 02:37 PM
TriniTech
Nov 3, 2004 01:21 PM
snowseeker
Aug 31, 2004 11:33 PM
EkREV
Nov 24, 2001 11:11 AM
