clutch cable
they both were new and i have a clutch master stage 3 clutch and they told me it was a stock poundage pressure plate. and i am thinkin my pedals are bent.. i have a 91 cx sedan and also have 89 crx si pedal would they fit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’’Simon’’ »</TD></TR><TR><TD CLASS="quote"> and i am thinkin my pedals are bent.. i have a 91 cx sedan and also have 89 crx si pedal would they fit?</TD></TR></TABLE>
yeah I think so. take a look at it first though.
and its not the pedal that bends, its the brackets or "pedal assembely" that the pedals pivot on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’’Simon’’ »</TD></TR><TR><TD CLASS="quote">would it be possible for the pedal to be bent with out the bracket being bent</TD></TR></TABLE>
Have you taken a good look at it yet?
look at this thread for reference https://honda-tech.com/zerothread?id=2199051
It should be obvious if infact that is your problem.
Personaly I dont think the pedal itself would bend, the pedal is made of like 1/4 inch on 5/16 inch steel and the bracket is 1/16 inch or 3/32 inch sheet metal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane »</TD></TR><TR><TD CLASS="quote">Are you using a OEM cable? I went through a bunch of cheap clutch cables in my CRX then went to OEM and never had a problem again.</TD></TR></TABLE>
Same here Geoff, the OEM cable was much better built, the imposter cable had a lot of plastic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
Ditto. At least I got all my cables for free (cept the OEM one I finally bought) since a birdie brought them to me.
</TD></TR></TABLE>Ditto. At least I got all my cables for free (cept the OEM one I finally bought) since a birdie brought them to me.
USDM 4G VTEC
Jun 20, 2003 05:20 PM
