Wire colors black/yellow for d16y7 wire harness
Does anyone know what colors: Black/yellow and Red/yellow are for a 96-00 civic d16y7??? I believe that red/yellow or solid red with yellow stripes are for the IAT Intake Air Temp.. but what is Black/yellow?
is it a thick wire? if so it goes to the dizzy, and i think ur correct about the iat wire. mine is red with a yellow stripe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggdogg »</TD></TR><TR><TD CLASS="quote">is it a thick wire? if so it goes to the dizzy, and i think ur correct about the iat wire. mine is red with a yellow stripe.</TD></TR></TABLE>
no.. its about the same size as the red/yellow wire.. Im guessing its a ground wire?? are the ground wires green/black and black/yellow???
Red/Yellow is definitely a color wire used for the IAT, but also for the EVAP Purge Solenoid Valve. There's also a Black/Yellow wire on the EVAP Purge Solenoid Valve. There are a couple more for the O2 sensors, among other things. Where exactly are the wires located? Are they on a plug together or loose?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon »</TD></TR><TR><TD CLASS="quote">Red/Yellow is definitely a color wire used for the IAT, but also for the EVAP Purge Solenoid Valve. There's also a Black/Yellow wire on the EVAP Purge Solenoid Valve. There are a couple more for the O2 sensors, among other things. Where exactly are the wires located? Are they on a plug together or loose?</TD></TR></TABLE>
well I have a 97 civic hatch with a jdm gsr swap obd2. The ecu is also jdm. I have a CEL for the primary o2 sensor which is code 41. Im trying to figure this out. I know that the jdm motors doesnt come with a evap purge solenoid right? so it would make sense then since I dont have a solenoid to plug it into.. Its 1 plug with 2 pins or wires connected to it.. both pairs are red/yellow and Black/yellow..
-iLLuZioN-B18C1
Oct 25, 2009 05:50 PM
meallout
Oct 20, 2008 08:13 AM
red1997civic
Dec 25, 2003 12:50 PM
LuderX
Jan 13, 2003 05:49 PM
