??? JDM B16A Intake Mani Question - IAT sensor ???
Old May 12, 2008 | 02:57 PM
chessmaster00's Avatar
Default ??? JDM B16A Intake Mani Question - IAT sensor ???
Whats up guys...need some advice. I've got a 97 civic ex coupe w/ a JDM B16A (2nd gen i think), swapped (w/ tranny and a p30 obd1 ecu, I'm told)...I bought the car w/ the swap already done, pretty clean...Anyway, the car was runnin a little funny (extra loud, bucked a couple times, and idle bogs then surges a bit)...so I checked cel codes (cel only comes on a couple times, then goes out when I shut off car)...stored code 3 (M.A.P. sensor), so I'm thinkin I have a leak at the intake mani...well when I'm about to get some other stuff done and I'm talkin with a mechanic friend of mine, explaining the situation, he points at an empty plug on the intake manifold and says, "what goes there?"...I told him I'm not sure but I know some things are left unhooked on JDM swaps. Now i can't stop wondering what it is...I've tried searching. It looks like a plug for a sensor and its located on the second runner of my intake manifold...there is a kind of oval shaped raised area with the connection in the center (tiny wire looking thing, looks kind of like a coaxle cable end) and what looks like a small screw hole on each side.......What goes here??? Is it my I.A.T sensor and if so, should it be hooked up??? Is there any reason why the sensor would have been moved to another area and where are the possibilities...I didn't want to replace an i.m. gasket if somethings just not plugged. Lil' help please.
Old May 12, 2008 | 04:34 PM
biggdogg's Avatar
Default Re: ??? JDM B16A Intake Mani Question - IAT sensor ??? (chessmaster00)
u got it! iat sensor , should have a red wire with a yellow or white line with a female style plug hooked up to it. also change ur map sensor with a known good one. i was having a bad idle with a bucking motion at slight off throttle tip-in. guy hooked up my car to one of those snap-on computer boxes and my map was all ove the place. supposed to have a steady line, also my tps was off .5mv. swapped em out walla! no more probs and hella gas mileage.
Old May 12, 2008 | 04:44 PM
Default Re: ??? JDM B16A Intake Mani Question - IAT sensor ??? (biggdogg)
Hey man...thanks...can you think of any reason someone would move the iat, maybe to the intake arm (see some folks talkin bout that)...I have a hard time believing this sensor just popped off (swap done in 2002)? and is the map sensor for b16a in the throttle body or where? (already bought new tps...just need to install this week).
CoastalSi
10
Jun 25, 2010 01:26 PM
jondaviseffect
Apr 16, 2007 05:24 AM
ShoGinn
Oct 12, 2004 01:42 AM
handa
13
Jun 28, 2004 06:31 AM
kell211
Oct 5, 2003 05:59 AM
