squeaking noise...need help
Old May 12, 2008 | 12:12 PM
civicb16eg's Avatar
Default squeaking noise...need help
My cousin has a 99 honda civic ex with a gsr swap and for some weird reason it started making a squeaking noise yesterday. The squeaking noise only happens when hes off throttle and the car is rolling but the noise is not there when hes on throttle. The car sounds perfectly fine when hes idliing. Sounds like the noise is coming from the passenger side wheel. Anyone with any ideas please chime in.. THanks
Old May 12, 2008 | 02:42 PM
civicb16eg's Avatar
Default Re: squeaking noise...need help (civicb16eg)
anyone?
Old May 12, 2008 | 04:56 PM
riceburnerryan's Avatar
i would say a loose belt, but thats kinda weird that it only happens not on the gas
Old May 12, 2008 | 08:18 PM
civicb16eg's Avatar
ttt
Old May 12, 2008 | 11:13 PM
civicb16eg's Avatar
anyone?? please help!! its annoying!
Old May 13, 2008 | 10:34 AM
civicb16eg's Avatar
Old May 13, 2008 | 07:22 PM
civicb16eg's Avatar
Nobody?
Old May 13, 2008 | 08:32 PM
elektronsi's Avatar
check all the accessory belts, i bet its one of those
Old May 14, 2008 | 11:53 AM
civicb16eg's Avatar
Default Re: squeaking noise...need help (elektronsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elektronsi &raquo;</TD></TR><TR><TD CLASS="quote">check all the accessory belts, i bet its one of those</TD></TR></TABLE>
what accesory belts are u referring too?
Old May 14, 2008 | 01:17 PM
immajackuup's Avatar
my *****
Old May 14, 2008 | 01:26 PM
Pleiadi79's Avatar
should be one of the bearings on the ac belt side or the bearing of the wheel or the belt a little un tensioned thats why when you switch off it "sounds" because the belt when you switches off relases from the thightening of engine rotation
Old May 14, 2008 | 01:46 PM
civicb16eg's Avatar
Default Re: squeaking noise...need help (Pleiadi79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pleiadi79 &raquo;</TD></TR><TR><TD CLASS="quote">should be one of the bearings on the ac belt side or the bearing of the wheel or the belt a little un tensioned thats why when you switch off it "sounds" because the belt when you switches off relases from the thightening of engine rotation</TD></TR></TABLE>
When u say the belt, you're talking about the timing belt correct?
Old May 14, 2008 | 01:51 PM
Pleiadi79's Avatar
no the other one!
if you have the time belt lose now your cousin is eating pistons and valves
Old May 14, 2008 | 03:07 PM
civicb16eg's Avatar
Default Re: (Pleiadi79)
how do i tighten that belt?
bpetruzzo
24
Jul 30, 2011 03:47 AM
hondahead_dave
Honda Civic (2006 - 2015)
May 11, 2011 06:40 PM
silentbeatz
Apr 11, 2007 09:49 AM
crxtreme27
May 11, 2005 09:05 PM
tweekerz
Jan 18, 2005 05:07 AM
