Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
OMNI titanium axels worth $$?
Old May 12, 2008 | 10:31 AM
Elwuudz's Avatar
Default OMNI titanium axels worth $$?
I'm not sure if my driving technique or new combination of components is to blame for my driverside axel bearing clicking like a beast.
Since I'm in the market to replace or upgrade I was wondering if those OMNI axels kingmotorsports carries would benifit me.
Is anyone was using these axels? And if so... is there a noticeable difference in the feel of the car by reducing the rotating mass on the drive train? not theoreticly but can you feel it.
Are these sticks worth the money or should I just run oem?
Old May 12, 2008 | 02:05 PM
TeamNextGenChris's Avatar
Default Re: OMNI titanium axels worth $$? (Elwuudz)
i can only imagine how much they cost,but there are plenty of other,better ways to spend that money.if you've optimized every other aspect of your car to the point that the only thing left is titanium axles....you should probably be racing something more exotic than a Honda.
plain old $60 reman'd liftetime warranty axles for my cars.
Chris
*edit:i just looked them up.$500 for just the shafts(so you'd still need to purchase new axles to use the joints from to make a complete assembly and fix your original problem) to save 4 pounds total?!!anybody who buys these should have them hand delivered by an assassin so that they can be shot in the head upon arrival*
Modified by TeamNextGenChris at 6:11 PM 5/12/2008
Modified by TeamNextGenChris at 6:12 PM 5/12/2008
Old May 12, 2008 | 02:32 PM
mc-integra111's Avatar
No need for titanium axles. If you break a lot of axles, then check all of your bushings (including engine mounts) and rod ends for wear. When these wear out, the geometry of the drivetrain is altered, which can break axles really quick (titanium or not).
Old May 12, 2008 | 04:02 PM
MSchu's Avatar
My Name is Nobody
Default Re: OMNI titanium axels worth $$? (mc-integra111)
If you burn through CV's, get RAXLES... Tell him you'd be using them for RR, it's the best $350-450 ever spent
That being said, I think I will get TI axles just because people said I shouldn't
Old May 12, 2008 | 05:48 PM
Chris F's Avatar
Default Re: OMNI titanium axels worth $$? (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">If you burn through CV's, get RAXLES... Tell him you'd be using them for RR, it's the best $350-450 ever spent
That being said, I think I will get TI axles just because people said I shouldn't </TD></TR></TABLE>
I bought a CF trunk to save a few pounds, and this is partially unsprung rotating weight
-Chris
Old May 12, 2008 | 06:26 PM
FifthGearOnline's Avatar
Default Re: OMNI titanium axels worth $$? (Chris F)
do they make cryo frozen axles for honda's?
Old May 13, 2008 | 03:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">:
in that case,i think you also shouldn't jump off a tall building.
Chris
Old May 13, 2008 | 05:01 AM
DrSeuss's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mc-integra111 &raquo;</TD></TR><TR><TD CLASS="quote">No need for titanium axles. If you break a lot of axles, then check all of your bushings (including engine mounts) and rod ends for wear. When these wear out, the geometry of the drivetrain is altered, which can break axles really quick (titanium or not).</TD></TR></TABLE>
Any other suggestions? My driver's side half-shaft only lasted 8 months before it started clicking again. I just had the front suspension apart for a spring change a couple of months ago and everything looked fine. I have ES inserts in the lower torque mounts and the rear mount and those also looked fine. The engine and tranny mount look like they've been on the car for a while but there are no tears or cracks.
It's an Autozone axle so I'm just going to ask for a replacement but if this keeps on happening, then I'm going to look for a better axle. No problems with my passenger side axle.
Old May 13, 2008 | 06:50 AM
Default Re: OMNI titanium axels worth $$? (DrSeuss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrSeuss &raquo;</TD></TR><TR><TD CLASS="quote">Any other suggestions?</TD></TR></TABLE>
I am not sure exactly which engine mounts have what from your comment, but any engine mount that is bad could cause this problem. My front engine mount (front of car, actually bolts to the tranny with 2 bolts) went bad and that caused my passenger axle to break.
If it is only happening on the drivers side, then my guess is to double check all the bushngs and ends on that side. If that is the side with the intermediate shaft, check those bolts and make sure that is tight. If it has the stabilizer bar thats goes the the front cross member, make sure that isn't bent or has a worn front bushing.
Also, when you do get the next axle, check the length carefully. If the current axle was actually the wrong part (I've had parts places do that to me before), maybe the length is just a little too long or short which would cause accelerated wear. Hopefully you have a repair manual for your car the gives what the correct length should be.
Old May 14, 2008 | 08:54 AM
Bbasso's Avatar
Tell Marty at http://www.raxles.com/ how you use the car and take his advice. I did and I have no more issues with axles.
Old May 14, 2008 | 07:28 PM
DrSeuss's Avatar
Ok, I'm an idiot. I can't get the stupid axle out. The last time I just pulled and pried and it poped out. Are there any magic pry points or techniques to get the driver's side axle out?
Old May 15, 2008 | 08:31 AM
Chris F's Avatar
Default Re: (DrSeuss)
I've had lots of problems prying it out in the past. I remember a normal hammer didn't work. 5-lb hammer worked on the first or second try, it needs a lot of momentum since the axle is a pretty heavy piece. You might need a punch or screwdriver or something to get the right angle on it, but I think you can just catch the edge of the axle with the hammer to get it out.
-Chris
Old May 15, 2008 | 12:53 PM
SHG_Beans's Avatar
Can't get it out of where? The hub or tranny? Just use a prybar with a long handle. Leverage ftw. Also, I've heard quite a few times RAXLES are the way to go.
Old May 15, 2008 | 03:08 PM
DrSeuss's Avatar
I can't get it off the intermediate shaft.
Yeah, I've been beating on it with a hammer and a long bar. I've also tried various pry bars in various configuration. The problem is there's a big gap between the housing and the intermediate shaft support that bolts on the back of the engine. I know it'll come out since i've gotten it out before. But that took a bunch of cursing and prying and didn't seem very inefficient. I'm just looking for a better way.
Old May 15, 2008 | 03:57 PM
B18CXr's Avatar
Why not use OEM?
They will hold +500bhp, it's all in how you use the loud pedal.
Old May 15, 2008 | 03:59 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrSeuss &raquo;</TD></TR><TR><TD CLASS="quote">I'm just looking for a better way. </TD></TR></TABLE>
Bigger hammer. Really.
Old May 15, 2008 | 04:04 PM
Default Re: OMNI titanium axels worth $$? (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">Why not use OEM?
i've got to agree.for my daily driver/track car or my 300WHP(soon to be 500ish WHP and still on stock axles) street car on 24.5" slicks,i'm fine with reman'd axles.
some people can tear up an anvil.
chris
Old May 15, 2008 | 07:00 PM
DrSeuss's Avatar
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Bigger hammer. Really.</TD></TR></TABLE>
Well I'm swinging a 5lb hammer. Had to stop for tonight since my arm was getting tired and it was getting dark. I'll try raising the car higher so I can get a better swing at it. I'll have to use some pieces of wood with my jack since I'm close to the max height of my jack. Anyway I started with a piece of wood braced against the axle, then I tried a big spade punch, then I resorted to just banging on it but it started sparking so I'll give the piece of wood another try.
I'll give the reman'd axle another shot. It's just this last one lasted about 8 months before it started ticking again. The axle that came with my swap about 1 year. I have a stock B18C motor with some bolt ons. The tie rods are new and seem fine. At least they pass the wiggle test. The lower control arm bushings also look fine. And the intermediate shaft is bolted tight to the back of the block.
Old May 15, 2008 | 07:12 PM
Elwuudz's Avatar
Default Re: OMNI titanium axels worth $$? (TeamNextGenChris)
Its my driving technique until I learn better.
But this is now the least of my problems after finding I had spun my 2nd cylinder main bearing on a newly swapped sir2
Time for the b20vtec to become a reality
wish me luck
Hopefully I get the power I'm looking for this time around
Old May 16, 2008 | 02:58 AM
I'll give the reman'd axle another shot. It's just this last one lasted about 8 months before it started ticking again. The axle that came with my swap about 1 year. I have a stock B18C motor with some bolt ons. The tie rods are new and seem fine. At least they pass the wiggle test. The lower control arm bushings also look fine. And the intermediate shaft is bolted tight to the back of the block. </TD></TR></TABLE>
you're not leaving the car on just the jack when you get under there are you?!definitely make sure it's secure before you get under there swinging a hammer!
i've found that if you're prying/beating on one side of the axle hub,it can bind it and keep it from coming out.try two prybars or large flat-head screwdrivers 180 degrees from each other,wedging between the axle hub and intermediate shaft housing.this will let you pull straight out on it,and usually works.
Chris
Old May 16, 2008 | 04:40 AM
DrSeuss's Avatar
Default Re: (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
No no, I don't have a death wish. The car is on jack stands. I just have my 17" harbor freight aluminum jack so it doens't lift very high. I need to get my bigger jack from my friend.
The dual prybars is my normal technique but I didn't seem to be making alot of progress. I'll just keep working at it. I don't need the car again until the 30th so I have some time to mess around with it.
Old May 16, 2008 | 05:33 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">If you burn through CV's, get RAXLES... Tell him you'd be using them for RR, it's the best $350-450 ever spent </TD></TR></TABLE>
Ditto on that. That guy is absolutely tremendous with service and quality.
He must be an enthusiast himself, because he always seems very interested in what you're doing.
cornflake-dc2
Dec 21, 2007 06:23 PM
lude98SH
Apr 19, 2007 06:04 AM
Jacen
Sep 12, 2004 05:18 AM
Phil B
Dec 22, 2001 11:49 AM
