How much nitrous should I use?
Old May 12, 2008 | 10:14 AM
crxrider07's Avatar
Default How much nitrous should I use?
If I decied to use nitrous on my ls motor, what is the most I can use without blowng any thing?
Old May 12, 2008 | 10:29 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: How much nitrous should I use? (crxrider07)
Stock motor?
Willing to upgrade things?
Just asking for a random number?
What kind of kit are you running?
Old May 12, 2008 | 10:51 AM
crxrider07's Avatar
Default Re: How much nitrous should I use? (***$nyper)
Yes the motor is stock and it is a NOS universal kit. Yeah i am willing to upgrade a few things.
Old May 12, 2008 | 10:53 AM
ProjectSIR's Avatar
Make sure you get iridium plugs, and upgraded iginition, and i wouldnt run anything over 75 shot, and i wouldnt even run 75, max I ever shot is 60
Old May 12, 2008 | 11:07 AM
crxrider07's Avatar
Default Re: (ProjectSIR)
thanx. how was it when you used the 60 shot? was there a big difference?
Old May 12, 2008 | 12:09 PM
carnz98gsr's Avatar
pushing a button and adding ~60hp...hmm i believe it'd feel like a big difference
Old May 12, 2008 | 12:20 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectSIR &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you get iridium plugs, and upgraded iginition, and i wouldnt run anything over 75 shot, and i wouldnt even run 75, max I ever shot is 60</TD></TR></TABLE>
Wrong wrong annnnnnnd wrong.
1) Iridium plugs are the WORST thing you can do for your motor. Get NGK coppers in the correct heat range.
2) Stock honda igntions have made upwards of 600~ hp, so i think properly operating ignition components are more important then red or shiny ones.
3) The real way to quote unquote safely use nitrous is to MAKE SURE YOU ADD THE DAMNED FUEL. The only time you should EVER use a dry shot system is when the ecu is calibrated (via hondata or the like) to shoot a hell of alot more fuel.
Nitrous has a greater release of energy per cubic inch then ambient air does (alot more). So basically think of it as cramming more air into your cylidner. What does more air require? MORE FUEL!! And anyone that tells you that your o2 sensor will compensate for the difference should put it on paper so you can send them a bill for a new block when you detonate a piston through your cylinder wall.
The point of the story? Use a calibrated wet shot or tune the **** out of it so when you're WOT and the nitrous is flowing its dumping a LOT more fuel. The road to hell is paved with good intentions..... and dry shot systems.
Old May 12, 2008 | 12:26 PM
ProjectSIR's Avatar
my iridiums worked fine descendants , but others would prolly work i dont have a masters degree in n20 like you apparently, and my motor is still fine.
Old May 12, 2008 | 12:48 PM
coupej1's Avatar
get 2step colder ngk plugs then stock, stock ignition is fine and make sure you have the fuel to keep from running lean. if you have everything and its a good running motor i wouldnt be scared to run a 100shot, i run a 75 shot on my single cam vtec and havent had any prob.
Modified by coupej1 at 5:52 PM 5/12/2008
Old May 12, 2008 | 01:19 PM
ComeOnKip's Avatar
I dont have a masters degree in anything, just a general understanding of how combustion motors work
Some people swear by iridiums, I've seen nothing but dyno-days ruined and replacing them for the cheap (but still very effective) copper NGKs.
924doorEG
17
Oct 22, 2007 08:20 PM
foowitdaredek
22
Apr 30, 2007 12:43 PM
HONDAVTIS
Oct 20, 2006 08:45 AM
faSHOwidIT
Sep 23, 2006 12:52 AM
EEK
Jun 4, 2002 09:01 AM
