IACV stuck closed...
Old May 12, 2008 | 09:54 AM
RaWrZie's Avatar
Default IACV stuck closed...
Ok so I've come to the conclusion that my IACV is stuck closed.
Is there a way to fix it?
I really don't want to buy a new one since they are almost $200 at AutoZone. (2 year warranty.)
Old May 12, 2008 | 04:45 PM
RaWrZie's Avatar
Default Re: IACV stuck closed... (RaWrZie)
Bump.
Due to being on 3rd page.
Any input is helpful.
Old May 12, 2008 | 04:48 PM
cherroneballs's Avatar
I'd like to know too, I think mines stuck also, throwing cel for iacv and cold start to allthe way warmed up, my idle stays at 800,
Old May 12, 2008 | 04:59 PM
biggdogg's Avatar
Default Re: (cherroneballs)
top of the page FAQ`S has a write up on it.
Old May 12, 2008 | 05:04 PM
super_coo's Avatar
If yours is a 94' like your signature there's some cheaper ones on ebay if those would work for you.
Old May 12, 2008 | 05:14 PM
RaWrZie's Avatar
Default Re: (biggdogg)
I think I am blind.
I only see FITV.
Old May 12, 2008 | 05:16 PM
RaWrZie's Avatar
Default Re: (super_coo)
I'll have a look.
Not picky with brands but at least a known one.
Old May 12, 2008 | 09:04 PM
wondersparrow's Avatar
I dont think there are aftermarket ones. at least I havent seen any. you could just adjust the idle and forget about it. it will throw a code. IACV really only makes a difference at warm idle and prevents engine from stalling when you let of the gas. aside from that, check autowreckers and stuff.
Edit: I think there is a way to jump the wires to get rid of the code actually.
Old May 12, 2008 | 09:12 PM
RaWrZie's Avatar
Default Re: (wondersparrow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wondersparrow &raquo;</TD></TR><TR><TD CLASS="quote">I dont think there are aftermarket ones. at least I havent seen any. you could just adjust the idle and forget about it. it will throw a code. IACV really only makes a difference at warm idle and prevents engine from stalling when you let of the gas. aside from that, check autowreckers and stuff.
Edit: I think there is a way to jump the wires to get rid of the code actually.</TD></TR></TABLE>
Idle is 1.2k steady.
Not good.
And that's with the screw as far in as it could go.
That's why I need to hopefully fix my IACV since it seems to be stuck closed.
Old May 13, 2008 | 05:37 AM
you idle at 1.2k and still no vacuum on that top hole? you must have a vacuum leak somewhere. the IACV is prolly closed because you are idling that high, there isnt much it can do for you other than make it idle higher. is there vacuum on the bottom port when your engine is warm? I'm going to get a throttle body gasket myself because I noticed it was leaking when I cleaned it.
dllnzek
Aug 15, 2012 10:42 PM
MMMm Waffles
Jun 28, 2008 02:58 PM
JSR
May 17, 2006 10:27 PM
90LSpimpin
Nov 15, 2004 08:21 PM
JDMorgan
Jun 9, 2004 02:02 PM
