back firing when vtec engages??
Old May 12, 2008 | 06:16 AM
spinksy's Avatar
Default back firing when vtec engages??
yo
well got abit of a problem at minute -
ive had a slight miss fire for awhile but this is because i havnt got my ignition timing spot on -
the real problem ive got now is when i hit vtec my car splutters and back fires badly! its really bad - what could this be?
ive cleaned my spark plugs, will be getting new ignition leads at the weekend -
i thought this might be something to do with the vtec solenoid??
any suggestions?
Old May 12, 2008 | 06:58 AM
Brick Top's Avatar
Default Re: back firing when vtec engages?? (spinksy)
the vtec solenoid has nothing to do with that. sounds more of a spark/fuel issue. what ecu are you using? any check engine lights?
Old May 12, 2008 | 07:03 AM
spinksy's Avatar
Default Re: back firing when vtec engages?? (Brick Top)
right ok-
im running standard ecu which has been mapped on crome by a friend - was done about 15 months ago and has been fine!
no check lights at all - think ill replace the plugs and leads at weekend.
anymore suggestions?
Old May 12, 2008 | 12:37 PM
spinksy's Avatar
anyone....
Old May 12, 2008 | 12:39 PM
quicksilver1689's Avatar
i ♥ snails
if its not a forced induction setup then u could try going to a stock BIn see how it runs.
Old May 12, 2008 | 01:11 PM
blk92_d16's Avatar
So what changes to the car have you made recently before this had started?
Old May 12, 2008 | 01:36 PM
spinksy's Avatar
Default Re: (blk92_d16)
no changes - thats whyi cant work it out.
i was racing it down the 1/4 mile the day before it started an it was fine then
it just started up randomly...
sanman000719
Sep 5, 2012 06:05 PM
zenon8890
Aug 18, 2007 11:32 AM
curtisb16
Jul 26, 2007 07:01 AM
Jahtoot84
Jun 21, 2005 06:46 AM
