ARGH Supension noises help!
Old May 11, 2008 | 11:35 PM
BKKloppenborg's Avatar
Default ARGH Supension noises help!
Hey guys well another suspension issue for me, about 2-3 months ago needed new axle boots, and Axle. Now i notice when i am driving and hit a bump, dip, or just uneven road, or anything like that. (Low speed about 5-15) I get a crick/rattling sound. sounds like it is coming from the Front of the car only. So correct me if i am wrong, either it could be a engine/Trans mount or what else? Side note: Also vibrates on acceleration. What test/tests can i do to figure out the problem? Thanks, Brian
Old May 12, 2008 | 12:55 AM
Jimmy's Avatar
Global Moderator
Vibration upon acceleration = Axle.
Did you ever replace them?
Old May 12, 2008 | 07:01 AM
hatchtegman's Avatar
sounds like they are not in all the way if they are new. then maybe your axle seals are gone, and maybe if not that then they are not engaging into the trans, and halfshaft all the way. they have to have no space there. and also make sure your axel nuts are tight, i forget the torque specs but that can cause noises too !
good luck
Old May 12, 2008 | 08:15 AM
Default Re: (Jimmy)
The honda dealership was supposed to replace the font axle, but i doubt their ablility since they put the axle boots in wrong, resulting in the axle going bad and them replacing it. *Sigh* i guess i will go back to them for the third time and have them check it.....
Old May 12, 2008 | 03:54 PM
g2daturbo's Avatar
Default Re: (BKKloppenborg)
sounds like a bad axles... get a new axle!
tylerp318
Oct 26, 2014 08:36 AM
wu tang
14
Dec 17, 2007 09:23 AM
Rocks
Jun 28, 2004 11:06 AM
JSpin
Mar 26, 2004 08:52 PM
1 speedstar
Jul 18, 2003 03:58 PM
