auto ecu to 5 speed
Old May 11, 2008 | 08:31 PM
highrev98civic's Avatar
Default auto ecu to 5 speed
i was wondering is it possible to make a obd2 auto ecu to a manual? i know you can on obd1. is it the same way? need to know asap also has anybody tried to change an obd2 ecu to a manual? did it work or fail?
Old May 11, 2008 | 09:29 PM
danomatic93's Avatar
I have only heard that you cannot convert and ODBII ECU to manual.
Old May 12, 2008 | 12:11 AM
Default Re: (danomatic93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danomatic93 &raquo;</TD></TR><TR><TD CLASS="quote">I have only heard that you cannot convert and ODBII ECU to manual.</TD></TR></TABLE>
damn thats not cool! has anyone heard other wise?
Old May 12, 2008 | 10:45 AM
does anyone know how to get rid of a automatic tranny code (cel 70) in the auto ecu?
Old May 12, 2008 | 11:06 AM
Relic1's Avatar
If you have a manual trans, pick up a manual ECU.
If you have an auto and are simply trying to get rid of the CEL, why not find the problem.
OBD2 ECUs can not be converted from auto to manual like OBD1 ECUs can.
Old May 12, 2008 | 12:20 PM
BWoolard's Avatar
Just did the swap myself with the OBD2 and you do have to buy a manual ECU.
Old May 12, 2008 | 02:48 PM
the thing is i need the ecu for my emissions test! some one told me that i need the ecu that came with my car because it has the vin in the ecu that the obd2 reader will see. can anyone confirm this fact or myth? any one here with experience on emissions testing in VA? any advise would be helpful
Old May 12, 2008 | 02:55 PM
Relic1's Avatar
Honda ECUs have no clue what the VIN is. (pre2002 for sure, not sure about later versions)
In VA, No CELs = pass.
Get a manual ECU and drive on it for a few days to clear the readiness flags, then take the test.
Old May 12, 2008 | 03:27 PM
twinloop's Avatar
Default Re: auto ecu to 5 speed (highrev98civic)
If ur afraid there going to check the numbers on the ecu keep the orig. ecu and get a manual ecu and just switch out the boards. Its a lil bit of a pain in the as but its poss. my friend did in up in Redding,CA. to pass the B.A.R.
Old May 12, 2008 | 09:07 PM
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">Honda ECUs have no clue what the VIN is. (pre2002 for sure, not sure about later versions)
Get a manual ECU and drive on it for a few days to clear the readiness flags, then take the test.</TD></TR></TABLE>
i hope ur right! can anyone in VA confirm this? has anyone in VA passed with a ecu that was not stock(the original that came with the motor)?
Old May 13, 2008 | 02:51 PM
need to know asap
RACEPAK
Oct 7, 2007 07:15 AM
Slamaccord
Jun 18, 2007 03:33 PM
99ekb18b
May 29, 2007 06:41 AM
murmur9
Aug 27, 2004 09:10 AM
