Need a tad bit of help H-T...
Old May 11, 2008 | 06:41 PM
st9vex's Avatar
Default Need a tad bit of help H-T...
About to finish my setup, but have a quick question about the oil line running from the oil pan to the turbo. My boy says that since the block is aluminum, which are all d16y8 OEM blocks aluminum? It would be hard to weld, and something about how if you drill the hole, the oil pan could crack since it's aluminum, my question is how would I set this oil line up exactly? Thanks for the suggestions...
Old May 11, 2008 | 06:50 PM
st9vex's Avatar
Default Re: Need a tad bit of help H-T... (st9vex)
someone has to know...
Old May 11, 2008 | 07:34 PM
st9vex's Avatar
Also want to throw another question out there, is there a place that sells oil pans for my y8 that our pre-drilled and ready to go for turbo...?
Old May 11, 2008 | 08:30 PM
hotrod99's Avatar
Default Re: (st9vex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by st9vex &raquo;</TD></TR><TR><TD CLASS="quote">Also want to throw another question out there, is there a place that sells oil pans for my y8 that our pre-drilled and ready to go for turbo...?</TD></TR></TABLE>
Moroso makes pans for the d16 that are already pre tapped for an oil return line and oil temp.
Old May 11, 2008 | 08:47 PM
Schister66's Avatar
Man U FTW
The oil pan isn't alum. Its actually really easy to fit the return line into it. Plus, many oil line kits include a weld-less return bung.
Old May 12, 2008 | 10:41 PM
st9vex's Avatar
Do you guys know where I could find a weldless oil return bung from?
Old May 13, 2008 | 06:56 AM
Schister66's Avatar
Man U FTW
contact the user "Stealthmode62" and tell him about your issue
http://www.stealthmodeperformance.com
h23vtec_dc2
24
May 7, 2014 08:19 AM
mrdeadman
Jan 30, 2007 06:03 PM
MBlake55
Feb 27, 2006 10:18 AM
GruvyTune
Nov 12, 2001 04:07 PM
