suggestions on cleaning dyno rollers?
Old May 11, 2008 | 05:19 PM
Turbo-charged's Avatar
Default suggestions on cleaning dyno rollers?
i had a car come on my dyno that had its oil filter fall off and completely oil down the dyno. we had to take the dyno all apart and try our best to clean it. we "thought" we did a good job......but after that incident we cant get any cars to make more than 550 horsepower. all of the cars have proven at the track that they are making well over 550.
does anybody have any suggestions? your standard type of floor cleaners, degreesers, and brake cleaner didnt do the trick. i need some crazy illegal crap or something. does anybody have any ideas? dynojet wasnt much help
Old May 11, 2008 | 06:20 PM
MAX_CFM's Avatar
Default Re: suggestions on cleaning dyno rollers? (Turbo-charged)
I have seen race teams use Acetone to clean the rollers from rubber build up
not sure how it will work for oil ...
We have a dynapack so i havnt tried it
non-VTEC's Avatar
so the rollers are still covered in oil? wheels keep spinning on the dyno?
some heavy duty engine degreaser and high power pressure washer should blast the oil off......
Old May 11, 2008 | 06:46 PM
fastcody1's Avatar
is the roller covered in oil or do you think the optical trigger got soaked?
Old May 11, 2008 | 06:57 PM
Kevin's Avatar
Default Re: (fastcody1)
Maybe the stuff you used to clean it made it worse?
If it was me, i would scrub the **** out of it with a big brush and some undiluted simple green. Then do an acetone rub down after that to remove all traces of the cleaner as well.
Old May 11, 2008 | 08:06 PM
Default Re: (Kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevin &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the stuff you used to clean it made it worse?
If it was me, i would scrub the **** out of it with a big brush and some undiluted simple green. Then do an acetone rub down after that to remove all traces of the cleaner as well.</TD></TR></TABLE>
what you suggested is pretty much what we did, minus the acetone.
i partially think the optical trigger was effected because VSS from dattalogs vs. VSS on the dyno are very far off, which is obviously going to effect the power output as well. its hard to tell if its just from wheel spin though.
the dyno rollers are no longer "soaked" in oil......but cars are def. breaking traction easier than they used to. i would say at power levels they shouldnt be spinning at....but there is no possible way we are getting accurate numbers. im going to try to inspect/clean the pick up in the morning.
to give an idea i had a 42r car making 550 @ 30psi.....which is clearly wrong...and at the same 30psi it went 148 at the track, falling on its face between the 1-2 shift...so it had more in it at that boost level. id say we are an easy 150 horsepower off.....the amount of fuel being used agreed with the estimated power and trap speed as well.
Old May 12, 2008 | 07:28 AM
denske's Avatar
Default Re: (Turbo-charged)
was wondering if you could use some VHT track bite on the rollers, or does that only work on asphalt?
Old May 12, 2008 | 09:23 AM
Dr Pooface's Avatar
If it's slipping that bad won't there be an obvious discrepency between mph measured at the dyno and shown on the cars speedo?
Old May 12, 2008 | 09:46 AM
HT Chaplain's Avatar
Loved
Did the car blow up when the filter fell off?
Old May 12, 2008 | 05:00 PM
Default Re: suggestions on cleaning dyno rollers? (HT Chaplain)
no....the filter fell off when cruising only going about 20mph. it just made a mess. a big one.
there is a difference in speed on the dyno and the logs.
i had another car on the dyno today that made 550...however on this one 550 is about right. i cleaned off the pick up today and cleaned up a little bit more.....so hopefully its something that will wear off with time.
i have to tune a car with a s372 1600s and 5 bar tomorrow so that should give us a better idea of whats going on. and then another car with the same set up on thursday.
wednesday is a rwd turbo car....they seem to hold traction up to 1000whp effortlessly, so hopefully that will give us a better idea of whats going on too.
Old May 12, 2008 | 05:55 PM
manifoldmiketyson's Avatar
laquor thinner will work better the acitone. it will take the paint off too probably.
you could probably burn it off with a map gas torch. don't hit it too hard though.
Old May 12, 2008 | 09:34 PM
mrbsponge's Avatar
i had to use paint thinner in a hand pumped sprayer like what you use to spray insecticide. we had a rearend come apart on our rear rollers and that redline gear oil is a friikin mess. then they left it there overnight and didnt clean it up till the morning, wow!
thank god we still have 2 more rollers on the front. its the only good thing about an awd dyno!
Old May 12, 2008 | 11:22 PM
xxbulaxx's Avatar
Default Re: (mrbsponge)
Clean it with Thinner/Acetone. Then when it's dry spin the roller and spray it with VHT.
Then come back and tell me the cars won't hook.
Old May 14, 2008 | 03:05 PM
Pleiadi79's Avatar
Default Re: suggestions on cleaning dyno rollers? (MAX_CFM)
use the acid for specific for degreasing floors
90blackcrx
Nov 7, 2009 12:33 AM
emotionisdead
May 3, 2005 11:00 PM
Pikachu
Apr 11, 2005 06:45 AM
done
Jul 28, 2004 07:02 PM
teg92
Aug 15, 2003 04:12 PM
