starting click
Old May 11, 2008 | 04:00 PM
(760)doogie's Avatar
Default starting click
hey i tried starting my new engine today, it was cranking but wouldn't start and this was with my dad's tundra jump starting it. so then i just switched my battery with his and it blew a 10 amp fuse under the dash so i changed it and now i just get a click and it loses power. could it be my main relay? im stuck right now i need this car running
Old May 11, 2008 | 04:20 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: starting click ((760)doogie)
check grounds. on thermostat, engine and tranny. power cables too.
Old May 11, 2008 | 04:29 PM
Default Re: starting click (2fast4u831)
they're all fine. could the battery from the truck be to powerful and blew more than just a fuse
Old May 11, 2008 | 06:34 PM
hayabusa160's Avatar
no all batterys are 12 volt. unless you crossed the terminals and blew some **** up.
Old May 11, 2008 | 10:05 PM
Default Re: starting click (hayabusa160)
but the cold cranking amps are different. it blew the main relay/starter solenoid/ecu/icu fuse
Old May 12, 2008 | 08:04 AM
so could it be anything else, like the main relay
Old May 12, 2008 | 08:35 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by (760)doogie &raquo;</TD></TR><TR><TD CLASS="quote">so could it be anything else, like the main relay</TD></TR></TABLE>
main relay could be bad. try another one. did you check for spark?
Old May 12, 2008 | 10:34 AM
Default Re: starting click (h22crxpwr)
spark where?
Old May 12, 2008 | 10:47 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by (760)doogie &raquo;</TD></TR><TR><TD CLASS="quote">spark where?</TD></TR></TABLE>
your sparkplug wire.. take it out and point it at something thats grounded. if a spark shoots out when you crank it over then you have spark. if not then you have a problem with either the dizzy or the main relay or some ignition related problem.
Old May 12, 2008 | 11:20 AM
i doubt there is because right when i turn the key to start the car , it makes a click and then everything turns off. im going to check my starter to see if that still works by connecting the power and the terminal with the wires, not the ground. how can i know if the main relay is toasted
Old May 12, 2008 | 11:28 AM
shad0wslay3r's Avatar
Bad Ground is my guess
Old May 12, 2008 | 01:09 PM
Default Re: (shad0wslay3r)
you would think, ill keep looking maybe some ground came loose under the dash but it doesn't make any sense because all i did was change the battery
EK B18c
22
Apr 21, 2012 03:08 PM
si90rex
Jun 24, 2007 05:53 PM
rass1313
Apr 14, 2006 02:41 PM
jaje
Jun 14, 2002 01:07 PM
