Water temp not Heating up fast.
Old May 11, 2008 | 03:02 PM
mn_babyboy's Avatar
Default Water temp not Heating up fast.
Problem, Car takes long to heat up, when driving the temp goes cold. Check engine comes on after a couple of mins warming up. But it doesn't throw a code?????
I think it's the thermostat. But I try using a different thermo, but used thermostat. After changing the thermostat, it doesn't drop down as far or as fast. But still take a long *** time to heat up. I guess I'll just go get a new one from honda.
Can anyone help shine in on this.
Old May 11, 2008 | 04:35 PM
lmike6453's Avatar
definitely thermostat...if you want the car to heat up faster get a half size radiator
Old May 11, 2008 | 04:55 PM
mn_babyboy's Avatar
Thats what I'm thinking also. I got a type r rad. Ohh why does honda closed on Sunday... I can't wait to fix this problem.
Old May 11, 2008 | 07:49 PM
94GeeSeeR's Avatar
Hahahaha.. better stick with the regular radiator hose... And just replace the thermostat with a new one.. Will probably fix your whole problem.
Old May 14, 2008 | 07:19 PM
mn_babyboy's Avatar
Default Re: (94GeeSeeR)
replace the thermostat and the fix the problem. Funny thing now is that When I had low coolant vtec worked. But I refilled the coolant and after 20 mins driving vtec wont kick.
Also CEL takes about 10 mins to come on???? But wont throw a code.
Old May 15, 2008 | 05:05 AM
lmike6453's Avatar
i guess check your oil and oil pressure?
Old May 15, 2008 | 05:43 PM
mn_babyboy's Avatar
Default Re: (lmike6453)
Check the oil level and it's fine.
Old May 15, 2008 | 06:12 PM
vladd's Avatar
Default Re: (mn_babyboy)
the coolant level doesn't affect vtec in any way. what's the cel code? there has to be one, you're not checking for it correctly if you're saying it's not giving you the code.
Old May 15, 2008 | 06:16 PM
90_EX_Civic's Avatar
Default Re: (vladd)
have you reset the ecu?
Old May 15, 2008 | 08:51 PM
mn_babyboy's Avatar
Default Re: (90_EX_Civic)
I reset the ecu so many times. still wont go away.
It wont throw a code. I mean the CEL doesn't even come on till 10 to 20 mins of driving?
Thanks for all the help. Keep it coming. I won't rule anything out till that CEL is gone.
Old May 15, 2008 | 09:02 PM
goota's Avatar
Okay, youre problem is your thermostat, it is getting stuck open, replace it and youll be fine.
and Type R radiators are NOT different than any other 94-01 manual integra radiator.
Old May 16, 2008 | 06:52 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mn_babyboy &raquo;</TD></TR><TR><TD CLASS="quote">I reset the ecu so many times. still wont go away.
Thanks for all the help. Keep it coming. I won't rule anything out till that CEL is gone.</TD></TR></TABLE>
you should be able to check the code with the car running.
Old May 16, 2008 | 11:36 AM
mn_babyboy's Avatar
already got the thermostat fixed. I think it might be the hondata throwing CEL because of something is wrong. But who knows.
It takes about 10 to 20 mins for CEL to come on.
Old May 16, 2008 | 08:12 PM
SuckMyDOHC's Avatar
Default Re: (goota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goota &raquo;</TD></TR><TR><TD CLASS="quote">
and Type R radiators are NOT different than any other 94-01 manual integra radiator.</TD></TR></TABLE>
Yes they are.
Old May 17, 2008 | 05:35 AM
Dogginator's Avatar
Daisy... Daisy...
It takes about 10 to 20 mins for CEL to come on. </TD></TR></TABLE>
You tried the paper clip method from the FAQ to pull the stored CEL code?
Old May 17, 2008 | 05:46 AM
mn_babyboy's Avatar
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
You tried the paper clip method from the FAQ to pull the stored CEL code?</TD></TR></TABLE>
I've tried and tired over and over again. I think it might be my hondata.
But who knows.
The other day vtec wouldn't kick in, but today it kick in.
azack_J
Nov 6, 2015 04:38 PM
ARMED
Honda CR-V & Element
May 3, 2014 09:28 AM
mrx
Jul 4, 2006 07:44 AM
