Teg wont stay idling from high RPM....need some advice
Old May 11, 2008 | 11:17 AM
lsturbo*'s Avatar
Default Teg wont stay idling from high RPM....need some advice
I have a freshly rebuilt 98 LS that will idle good at about 650RPM which is a little low, but runs great. However, when I am driving and come down from 3K or so the engine cannot recover and stalls out. Could it be my TPS,(throttle positioning sensor)? I took it of and checked resistance(or voltage, I forget the precedure) and it was within spec. Also, I cannot up my idle because that damn idle screw is stripped(I swear the screw must have been loc-tited in there!) How can I fix this, remove the TB and get it drilled/re tapped out or something?
Thx
Old May 11, 2008 | 04:59 PM
HONDRETTI's Avatar
Default Re: Teg wont stay idling from high RPM....need some advice (lsturbo*)
im having a similar problem... when im idling normally at a stop, my rpms will suddenly drop and ill stall unless i blip the gas. sometimes it doesnt happen at all, other times it happens at every stop. it sucks. i installed a brand new thermostat, tps, and iacv, and it still hasnt gone away. no cels.
Old May 11, 2008 | 07:47 PM
94GeeSeeR's Avatar
May want to look at this post.. It might help your problem.
***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve
https://honda-tech.com/zerothread/1575913
Also check and make sure you have no air in your cooling system. It will make for eractic idle as well.
I would check for air in the cooling system first.
Old May 12, 2008 | 06:17 AM
HONDRETTI's Avatar
Default Re: (94GeeSeeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94GeeSeeR &raquo;</TD></TR><TR><TD CLASS="quote">May want to look at this post.. It might help your problem.
I would check for air in the cooling system first. </TD></TR></TABLE>
already installed a brand new iacv from acura, cooling system already flushed.
Old May 12, 2008 | 07:07 AM
JDM_is_overrated's Avatar
Default Re: (HONDRETTI)
could be the spark plug wires
Old May 12, 2008 | 08:02 AM
HONDRETTI's Avatar
Default Re: (JDM_is_overrated)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_is_overrated &raquo;</TD></TR><TR><TD CLASS="quote">could be the spark plug wires</TD></TR></TABLE>
hey, im not sure it is but im willing to try anything. thank you.
any other opinions?
to the OP: do you have a lightened flywheel?
Old May 12, 2008 | 08:10 AM
scspeed's Avatar
Check vacuum lines?
Old May 12, 2008 | 09:17 AM
lsturbo*'s Avatar
Default Re: Teg wont stay idling from high RPM....need some advice (scspeed)
I dont know about Hondaretti, but for my case, my car runs perfect upon initial start(cause the idle is higher at cold temps) but when it heats up the idle is too low(still runs but too low). I honestly feel i just need to bump up the idle and I would be good because it runs great if I apply a slight amount of pressre to the gas pedal. How about this: can I just put a 1/2 turn tension on my throttle cable to keep he running at 750 RPM? I only ask about this cause my idle screw is stripped out.
decon
Dec 19, 2012 07:57 PM
z1gary
Jun 28, 2012 01:24 PM
2low93
Feb 17, 2012 04:13 AM
S13Morgan
Feb 18, 2010 05:10 PM
rx_86
10
Dec 28, 2008 09:14 PM
