Got a CEl p0453 need help
Old May 10, 2008 | 11:26 PM
hazard2o9's Avatar
Default Got a CEl p0453 need help
hey noob here my car got a cel P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage and i cant seen to find the problem can you guys please help me
Old May 10, 2008 | 11:55 PM
hazard2o9's Avatar
Default Re: Got a CEl p0453 need help (hazard2o9)
any one
Old May 11, 2008 | 06:39 PM
hazard2o9's Avatar
anyone out there that can help
Old May 11, 2008 | 07:45 PM
wonder squirrel's Avatar
What year car is it?
Old May 11, 2008 | 09:00 PM
hazard2o9's Avatar
Default Re: Got a CEl p0453 need help (wonder squirrel)
its a 97 honda civic ex with headers and inatake, cant seem to find the problem
Old May 11, 2008 | 10:11 PM
2000siturboR's Avatar
try reseting the ecu just disconnect the battery for 10 minutes or so and try again. i heard of people getting that code when they fill there car up all the way to the top of the filler neck.
Old May 12, 2008 | 08:51 AM
hazard2o9's Avatar
Default Re: Got a CEl p0453 need help (2000siturboR)
ive already try disconnecting the battery a couple times already and i also use an 0bd2 scanner to remove the code but when i drive a good couple miles here and there, the light pops back up
Old May 12, 2008 | 09:23 AM
Service manual says to check the vacumm hoses for disconnects, breaks, etc, and clogs. Otherwise, check the wiring, make sure there are no breaks, disconnects, and that all connectors are plugged in securely. I'd suggest going over the vacumm lines and wiring thoroughly, that likely your problem.
After all that, swap in a replacement ECM and see if the problem persists.
Goodluck.
Old May 12, 2008 | 12:10 PM
hazard2o9's Avatar
ill do that, thanks for the help
sPcIaLkSeRiEs
Sep 14, 2009 06:32 AM
skaternak
12
Aug 13, 2009 08:39 PM
Nate047
Oct 25, 2006 10:52 AM
gt25CIVICex
May 24, 2004 12:24 PM
M-EJ1
May 23, 2004 05:49 AM
