What is the vtec pressure switch?
Old May 10, 2008 | 08:52 PM
raidacaipo's Avatar
Default What is the vtec oil pressure switch?
Well Im running a stock JDM gsr motor odb2 in a 97 ek civic hatch with a usdm p72 ecu. I noticed the jdm motors dont have a oil pressure switch but just the solenoid. I dont have a oil pressure switch for now but I did wired the vtec solenoid straight to the ecu and vtec kicks in. I know the usdm ecus have to be wired to the vtec oiil pressure switch but not the jdm ecu. Is the vtec oil pressure switch important? what does it do? Do I need it and if so can I use a usdm b16
Modified by raidacaipo at 10:15 PM 5/10/2008
Old May 10, 2008 | 08:56 PM
BlueIntegraBoy's Avatar
Default Re: What is the vtec pressure switch? (raidacaipo)
The VTEC pressure switch allows VTEC work when there's oil pressure, since oil is very important for VTEC engagement. Basically it's a safeguard for us. However, it's not really needed.
Old May 10, 2008 | 09:01 PM
raidacaipo's Avatar
Default Re: What is the vtec pressure switch? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">The VTEC pressure switch allows VTEC work when there's oil pressure, since oil is very important for VTEC engagement. Basically it's a safeguard for us. However, it's not really needed.</TD></TR></TABLE>
So I dont really need it? what is the safeguard? how does it protect it? I just want to be on the safe side.
Old May 10, 2008 | 09:31 PM
It's a safeguard so if you have less oil than needed to activate the switch, you won't be kicking VTEC and depriving other engine components of oil. All JDM engines don't have this pressure switch.
Old May 10, 2008 | 09:36 PM
raidacaipo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">It's a safeguard so if you have less oil than needed to activate the switch, you won't be kicking VTEC and depriving other engine components of oil. All JDM engines don't have this pressure switch.</TD></TR></TABLE>
oh!!! cool... thanks
Takumi Fujiwara
Jul 23, 2006 09:18 PM
blueeg
Apr 25, 2006 11:16 AM
jdmsiR20
35
Apr 3, 2005 01:32 AM
wannagofaster
Sep 4, 2004 03:25 PM
B16A1-EF9
Dec 13, 2002 03:51 PM
