SOHC Performance help...
all right...ive got a 2000 Honda Civic EX right now with a D16y8 in it...the only mods i have on it right now are a AEM Short Ram Intake, Megan Racing Muffler, MSD Super Conductor 8.5mm Plug Wires, NGK G-Power Plugs, Weapon R Strut Tower Brack, Summit Cross-Drilled/Slotted rotors, EBC Greenstuff Pads, and i have my timing advanced to 30'. I was Just curious what my next step should be...im looking to stay all motor with this build, so i dont know if i should do a header next or if i should do an intake manifold or a cam or what...so common fellow builders...GIMME SOME INPUT!!!!!
You're not going to make any sufficient power going N/A with your y8. You're best off buying a Greddy/Edelbrock turbo kit since both of them are CARB legal, I believe. But other than boost, the only thing you can do to make more power is to swap out your y8 for something else.
For a SOHC, boost is the only real way to gain for a lower price, unless you have plenty of money and desire a all-motor project. If your wanting to stay all-motor and make power cheaply, you'll be best with a b-series swap and go from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -JSpecEk*9- »</TD></TR><TR><TD CLASS="quote">you will bend a valve or damage a piston </TD></TR></TABLE>
Pretty sure he means ignition timing...didn't see anything about adjustable cam gears.
Ignition timing that far off is bad for the engine overall, most likely much worse mpg due to poor burning of the AF mixture, loss of power, added engine heat, added stress on engine internals, etc.
If you have those plugs fire too soon you're going to be pushing the pistons back down when they are trying to come up...(if it ignites)
Get a header and a nice flowing exhaust. Maybe hook it up with a more aggressive cam or something. There are tons of things you can do, but unfortunately they aren't going to do much to a D-series.
You'll get the most performance gains if you stick to suspension work--front/rear sway bars, front/rear strut bars, a nice coilover setup, etc.
If you're not interested in suspension stuff (i.e. you only want to go fast in a straight line), either turbo the D16 or just go for a B series.
i was reading in hondatuning that they have a forum call immortal D. and it calls for just a shitload of head work and a tad bit of bottom end work...and it'll be mashin on duals no problem...but i dont know...im just looking on some input on what to do...ive heard i can put some ZC pistons in my Y8 and theyll swap right in...is that true?? and i have a little bit of suspension work...i have a matrix fully adjustable kit and a weapon r strut tower brace...
http://www.c-speedracing.com/h...c.php
everything being stock, with pm7s/p29s, you're gonna have hella compression. more agressive cam will help with lowering your compression due to the valves being open for more degrees of duration, causing compression blowoff. pm7s out ot the jdm dohc zc or the 1st gen usdm integras (p29s) i believe are the same... same diameter (of course 75 mm), same pin hieg. get some shot-peened ls rods, different rod bolts, have the pin end re-bushed for the d series pistons, and the big end shaved for the d series crank journals... plus alot of other things....
i think that a SOHC wont necessarily mash on a DOHC because it has a lot of head work and some bottom end work... maybe a stock B16, and a fully built D16, but for the most part.. B series is where its at unless you boost that D
your best bet is swapping in a DOHC, unfortunately SOHC's don't respond too well to bolt-on's, if u wanna keep you SOHC your gonna have to spend some serious serious cash.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan »</TD></TR><TR><TD CLASS="quote">i think that a SOHC wont necessarily mash on a DOHC because it has a lot of head work and some bottom end work... maybe a stock B16, and a fully built D16, but for the most part.. B series is where its at unless you boost that D</TD></TR></TABLE>
It'd have to be a pretty unfair competition. My buddy's 89 Si had a rebuilt D16A6, and that car had equal, if not better acceleration than my 2000 Si with its original (stock) B16A2. Keep in mind that the EM1 is also several hundred pounds heavier.
You are not going to get a lot of power out of that Y8 unless you really build the motor from top to bottom. If you want to make the car a little more fun to drive I would suggest installing a light flywheel. You will see more results with the light flywheel then you will with all the other "junk" you installed already.
Modified by mechanix619 at 11:02 AM 5/13/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hushypushy »</TD></TR><TR><TD CLASS="quote">It'd have to be a pretty unfair competition. My buddy's 89 Si had a rebuilt D16A6, and that car had equal, if not better acceleration than my 2000 Si with its original (stock) B16A2. Keep in mind that the EM1 is also several hundred pounds heavier. </TD></TR></TABLE>
I should have been more clear.. i meant if the motors were both in a similar car *like both EG* then i think that the B16 would beat the D
I should have been more clear.. i meant if the motors were both in a similar car *like both EG* then i think that the B16 would beat the D</TD></TR></TABLE>
It's cool man, I was reinforcing your point. A stock B16 still has more horsepower than a D unless you have some serious business going on in there, plus DOHC VTEC will destroy its SOHC counterpart. My point was, the only way the D is going to beat the B is when there is some sort of unfair playing field.
ecosniper
40
Jul 18, 2011 08:25 PM
ramz7887
Jul 16, 2003 12:19 PM
