misfire pulling my hair out.
Old May 10, 2008 | 01:50 PM
eflove's Avatar
Default misfire pulling my hair out.
ok I have everything fixed and ready to go on my build. Only thing is I can not for the life of me fix this misfire. If you guys have any ideas I could really use them.
info: It happends at idle and under load.At steady speed its ok. It on cyl one. motor is a 96 gsr. Ecu is a obd 1 jdm gsr.
this is what I HAVE done.
I have replaced the injector. swapped ecu's. new plugs. new wires. new cap and rotor. swapped dist. checked 12v at the inj plug. checked it with a noid light. leak down test 4-5%. checked resistance of ground wire from inj plug to ecu. checked fuel pressure. checked to see if fuel rail was plugged. swapped map. checked timing both spark and tbelt.
It will just not go away. Thanks for any help.
Old May 10, 2008 | 06:44 PM
IMALLSLO's Avatar
Default Re: misfire pulling my hair out. (eflove)
Misfire or surge? Is it throwing a CEL or you just feel it?
Old May 10, 2008 | 10:51 PM
eflove's Avatar
Default Re: misfire pulling my hair out. (IMALLSLO)
misfire for sure. sounds like a wrx and feels like crap. no cel
Old May 11, 2008 | 01:43 PM
Maxcapacity's Avatar
Did you make sure the clips on the injector plugs are not off and that the plugs are not half way on? Using the right spec spark plug with correct gap? Thats all I can think of right now..
Old Jul 12, 2008 | 04:58 PM
MR.johnson's Avatar
Default Re: misfire pulling my hair out. (Maxcapacity)
ttt im having the same problem. i changed my O2 and in went away for a bit. then came back.
Old Jul 12, 2008 | 06:26 PM
1992Si's Avatar
Compression test...
Old Jul 13, 2008 | 05:24 AM
crazy-ej8's Avatar
have you made sure all your grounds are clean and tight?
Old Jul 14, 2008 | 04:47 AM
MR.johnson's Avatar
Default Re: (crazy-ej8)
just fixed mine. it was a bad burn on the chip. reburnt it on a new file and runs perfect.
SmaTTeRLegion
15
Sep 2, 2013 11:28 AM
egGSR_hi
May 16, 2009 12:23 PM
virusiidx
Jan 18, 2005 10:11 AM
LShatchie
Nov 17, 2004 02:55 PM
Kamin
Aug 3, 2002 12:08 PM
