grinding into third gear.
Old May 10, 2008 | 12:43 AM
kongzilla's Avatar
Default grinding into third gear.
Car shifts fine in all gear except for 3rd. There is a slight grind going into 3rd gear.
I can down shift into third with no grind just fine. While driving from 1st up, to avoid the 3rd gear grind, I go from 2nd into 4th back into 3rd and there is no grind. There is only grind when I go from 1st to 3rd or 2nd to 3rd.
any solutions? Motor is a h22a 5 speed
possibly a tranny flush will cure the problem?
Old May 10, 2008 | 04:31 PM
Lubo_25's Avatar
Default Re: grinding into third gear. (kongzilla)
a trans flush wont cure the h22a synchro blues...
Old May 10, 2008 | 08:27 PM
PolishSasquatch's Avatar
Default Re: grinding into third gear. (Lubo_25)
yeah its just 3rd gear synchro issue
Old May 11, 2008 | 02:14 PM
kongzilla's Avatar
how hard to fix? How much would it usually cost? cheaper to just replace the tranny?
Old May 14, 2008 | 02:15 PM
Lubo_25's Avatar
Default Re: (kongzilla)
always cheaper to replace...
Old May 15, 2008 | 09:44 PM
Socalstar951's Avatar
try running synchro mesh in your tranny....if this doesn't help at all replace the synchro
Old May 16, 2008 | 07:39 PM
96Spec Ek's Avatar
Default Re: grinding into third gear. (Socalstar951)
Get a copy of a helms manual, buy a new 3/4 gear synchro hub assembly from hondapartsdeals.com, Crack open the tranny case and read the manual. Oh and have a few beers too.
iBrandon
Aug 23, 2007 12:17 AM
HondaRcB
Nov 24, 2006 11:41 AM
vietnogi
Feb 2, 2006 11:36 AM
H2nr
Jul 12, 2004 08:52 PM
cr-x si
Apr 14, 2003 08:34 PM
