B20 with Skunk2 manifold problems.
Old May 9, 2008 | 07:44 PM
Mavrock's Avatar
Default B20 with Skunk2 manifold problems.
Im running a Skunk2 Intake manifold on my Non-vtec b20, and i seem to have a problem with my fuel rail not compressing on the injectors enough. My question is what are some of the rail you guys are using. i currently am using a B18a rail along with b18a injectors, and fuel squirts out of the rail, right at the top of the injectors. any suggestions?
Old May 9, 2008 | 08:16 PM
98vtec's Avatar
moderator emeritus
Default Re: B20 with Skunk2 manifold problems. (Mavrock)
do you have the plastic spacer and rubber grommet in the injector ports? Did the o ring on the top of the injector come off somehow?
Old May 9, 2008 | 08:20 PM
slowtegkauai's Avatar
Default Re: B20 with Skunk2 manifold problems. (98vtec)
Make sure you tighten the fuel rail all the way. Also make sure the o-rings on the top of the injectors didnt rip off or anything.
Old May 9, 2008 | 11:10 PM
Mavrock's Avatar
Ya the screens, and the o-rings are all intact. i orginally used the studs from the old manifold, but after i noticed it wouldnt tighten down all the way i switched to bolts. it just seems as if i need like another quarter inch of tightening, but the rail is directly on the manifold.
Old May 10, 2008 | 11:19 AM
Default Re: (Mavrock)
Can you turn the injectors with your fingers? Or move the injectors up or down?
Old May 10, 2008 | 12:23 PM
b19coupe's Avatar
Did you transfer the bottom seals from your old intake manifold?
Old May 10, 2008 | 12:28 PM
Mavrock's Avatar
Yes i can move the injectors. this is when they squirt heavily. i transfered the o-rings at the base of the injectors, but i thought that in the new manifold they sunk in farther.
Old May 12, 2008 | 02:20 PM
Mavrock's Avatar
Any ideas as to why it doesnt fit the same?
Old May 12, 2008 | 03:07 PM
all-mtr-teg's Avatar
Pics.
Old May 12, 2008 | 08:28 PM
Mavrock's Avatar
Old May 12, 2008 | 09:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mavrock &raquo;</TD></TR><TR><TD CLASS="quote">Yes i can move the injectors. this is when they squirt heavily. i transfered the o-rings at the base of the injectors, but i thought that in the new manifold they sunk in farther.</TD></TR></TABLE>
What injectors are they? Stock, RC, ect. Also is it an aftermarket fuel rail?
Old May 17, 2008 | 03:45 PM
Mavrock's Avatar
The injectors and the rail are stock b18a.
BUCK_NASTY
Mar 7, 2007 09:16 AM
B18 CYA
Jun 13, 2004 09:56 AM
phreakmang
Mar 15, 2004 02:43 PM
dabomb
Apr 17, 2003 02:22 PM
GruvyTune
Dec 6, 2001 06:02 PM
