skunk2 manifold problem - injectors
Old Mar 15, 2004 | 11:16 AM
phreakmang's Avatar
Default skunk2 manifold problem - injectors
The injectors have a gap in them after putting on the skunk2 manifold and tightening down the rail.
I know i saw something on this before, what is the fix?
Old Mar 15, 2004 | 11:35 AM
SpoolnG2's Avatar
Default Re: skunk2 manifold problem - injectors (phreakmang)
You know the injectors rings that go into the manifold? Its like a thick rubber ring and the bottom of the injector. You just use two of those. One goes in the hold on the manifold and the other sits on the bottom of the injector. Thats what i do with mine atleast and its fine.
Old Mar 15, 2004 | 01:27 PM
94gsr4dr's Avatar
Default Re: skunk2 manifold problem - injectors (SpoolnG2)
Interesting i didn't have a problem with mine
Old Mar 15, 2004 | 02:32 PM
Boofster's Avatar
Default Re: skunk2 manifold problem - injectors (94gsr4dr)
I know what you mean. The rubber parts don't actually go on the injectors because the base is too thick. Just rest them on top of it and tighten the fuel rail to spec torque. Watch them when you start the car because you might need to tighten a bit more but be careful not to go too far.
Mine is running great.
Old Mar 15, 2004 | 02:43 PM
phreakmang's Avatar
Default Re: skunk2 manifold problem - injectors (Boofster)
fixed it no problem thanks honda-tech (cheesy smile and thumbsup)
Eghatchgsr8
11
Sep 30, 2014 06:19 PM
Mavrock
11
May 17, 2008 03:45 PM
GsrRussell
Apr 14, 2008 11:34 AM
DaveF
May 20, 2004 11:41 AM
