Common size hex drive on asian bikes?
Old May 9, 2008 | 03:49 PM
__oversea's Avatar
Default Common size hex drive on asian bikes?
Old May 9, 2008 | 03:52 PM
GraphiteAccord's Avatar
Default Re: Common size hex drive on asian bikes? (__oversea)
4mm
Old May 9, 2008 | 04:41 PM
rdblckSV650S's Avatar
Default Re: Common size hex drive on asian bikes? (GraphiteAccord)
between 4-6mm
Old May 9, 2008 | 06:23 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: Common size hex drive on asian bikes? (rdblckSV650S)
i use the old trusty 6mm the most.
Old May 9, 2008 | 07:11 PM
EngineNoO9's Avatar
Default Re: Common size hex drive on asian bikes? (The Hooligan)
5mm for my hondas.... I've used it so often that I had to take it in for a lifetime guarantee replacement from craftsman since it was so worn out.
Old May 9, 2008 | 10:12 PM
AdeJong 03's Avatar
its between 4-6mm for me
why do you ask this?
Old May 10, 2008 | 02:24 AM
marmaladedad's Avatar
Wouldn't you be purchasing a whole set of hex wrenches? Who gives only one or two....??
Old May 10, 2008 | 05:21 AM
MSchu's Avatar
My Name is Nobody
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by __oversea &raquo;</TD></TR><TR><TD CLASS="quote">What's the most common hex drive size? </TD></TR></TABLE>
I give up, what ARE the most common sized allen wrenches?
Old May 10, 2008 | 08:16 AM
fatboy01's Avatar
Default Re: (marmaladedad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladedad &raquo;</TD></TR><TR><TD CLASS="quote">Wouldn't you be purchasing a whole set of hex wrenches? Who gives only one or two....??</TD></TR></TABLE>
+1. A set of metric hex wrenches is small and only costs a few $. It's better to have too many tools than not enough. Although I have a birth defect, which is the need to buy every tool needed for every job.
Old May 10, 2008 | 03:48 PM
Blahblah718293's Avatar
Default Re: (fatboy01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatboy01 &raquo;</TD></TR><TR><TD CLASS="quote">Although I have a birth defect, which is the need to buy every tool needed for every job. </TD></TR></TABLE>
funny whats it called? i think i may have it as well. **** i almost baught a global obdII scantool and i dont even own an obdII car...
anyway x2 on just buying him a whole set. what you gotta be careful about is the quality.
ive personally got a set of snap-on metric hex 3/8 drive sockets. and they havnt failed on me yet, or stripped anything. if you buy some cheap 2$ set at a gas station or at walmart, odds are they may break, or strip the hex. id say craftsman is a good bet, cause with snap on... its pretty much the most expensive tools you can buy, and i didnt even pick mine out.
Old May 10, 2008 | 04:25 PM
ucb's Avatar
ucb
Default Re: (Blahblah718293)
get a 10 piece T-handle set
Old May 10, 2008 | 05:12 PM
MSchu's Avatar
My Name is Nobody
Default Re: (__oversea)
LOL
Old May 10, 2008 | 10:01 PM
Sliced Beard's Avatar
Default Re: (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatboy01 &raquo;</TD></TR><TR><TD CLASS="quote"> Although I have a birth defect, which is the need to buy every tool needed for every job. </TD></TR></TABLE>
I have the disease in chronic form.......if you only knew the amount of tools that I have and what I have.
The only thing I need now is a couple lifts, a tire changer and a balancer and I have an entire shop. *sigh*
Old May 12, 2008 | 03:22 PM
Default Re: (DirtySol)
dont forget a brake lathe and alignment rack.
(edit)
*sniff sniff* does anyone smell acetelene?
Old May 12, 2008 | 03:42 PM
bad-monkey's Avatar
my gixxer is a mix of 4, 5, and 6.
honda's are mostly 5mm, though they use bigger sizes for bigger bolts.
G2_Fella
Welding / Fabrication
19
Sep 21, 2007 11:50 AM
Boriqua0555
Jun 30, 2007 01:16 PM
JDM_Frijoles
Sep 13, 2006 04:43 PM
Toda Party
Jan 2, 2006 02:28 PM
CRX-ZC
Oct 10, 2004 01:09 AM
