Honda S2000 Honda S2000
steering loose after coilovers installed
Old May 9, 2008 | 02:32 PM
J.nguyen's Avatar
Default steering loose after coilovers installed
I previously had espelir asd springs on MY00 and the ride was perfect etc until I purchased a set of buddyclub racing spec coilovers. got them installed and slammed it, since then my steering is really loose, ie on the free way the steering is extremely sensitive and easily moves left and right over any lil bump , reflector etc, and its pretty scary driving fast.. is this normal on s2k becoming slammed ? my settings are on 2 away from stiffest and the install was correct no need 2 worry about that.. juss havnt gotten alignment yet but still... the steering grips 2 any crease on the road and is a lil too "loose"
is all this normal, I know for integras / civics this wasn't much a problem in my prev cars
Old May 9, 2008 | 03:12 PM
RacerXI's Avatar
Default Re: steering loose after coilovers installed (J.nguyen)
Have you had an alignment?
Old May 9, 2008 | 04:46 PM
alexisthemovie's Avatar
Default Re: steering loose after coilovers installed (RacerXI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI &raquo;</TD></TR><TR><TD CLASS="quote">Have you had an alignment? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.nguyen &raquo;</TD></TR><TR><TD CLASS="quote">havnt gotten alignment yet but still...</TD></TR></TABLE>
Old May 9, 2008 | 06:59 PM
iam7head's Avatar
Default Re: steering loose after coilovers installed (alexisthemovie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.nguyen &raquo;</TD></TR><TR><TD CLASS="quote">I previously had espelir asd springs on MY00 and the ride was perfect etc until I purchased a set of buddyclub racing spec coilovers. got them installed and slammed it, since then my steering is really loose, ie on the free way the steering is extremely sensitive and easily moves left and right over any lil bump , reflector etc, and its pretty scary driving fast.. is this normal on s2k becoming slammed ? my settings are on 2 away from stiffest and the install was correct no need 2 worry about that.. juss havnt gotten alignment yet but still... the steering grips 2 any crease on the road and is a lil too "loose"
is all this normal, I know for integras / civics this wasn't much a problem in my prev cars</TD></TR></TABLE>
slamming is for race car on smooth race track, show queen or ricer
which one are you?
oh, yeah i already "bolded" your answer for you
Old May 9, 2008 | 07:27 PM
uhh i don't have that problem and $10 says i'm lower than him...
i have buddy club's as well.
Old May 9, 2008 | 08:49 PM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: steering loose after coilovers installed (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">slamming is for race car on smooth race track, show queen or ricer
thats not true... thats why you dont see honda-challenge cars that are tucking tire.
Old May 9, 2008 | 09:00 PM
SlammedDC2teg's Avatar
Default Re: steering loose after coilovers installed (Chris.)
You need to get your toe corrected, I bet its way off in the negative range. If you dont get it aligned it will eat up your tires in the next 5k.
Modified by SlammedDC2teg at 10:05 PM 5/9/2008
Old May 11, 2008 | 11:53 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris. &raquo;</TD></TR><TR><TD CLASS="quote">
thats not true... thats why you dont see honda-challenge cars that are tucking tire. </TD></TR></TABLE>
maybe they are engineered to have a shorted travel because they are running at a known track surface?(aka no bumps, dips, high way commute)
all you see it's slammed, they might have so much more done to it(shorten damper, stiffer spring, antibump steer, etc)
and when is the last time you see them running around town and attending hardparking meets?
your suspension need travel to work, this is as simple as that
Old May 12, 2008 | 08:11 AM
IIGQ4U's Avatar
Why run your coilovers so stiff for daily driving? You should run them as soft as possible to prolong their life. If your shocks are not adjusted properly on each corner, your car will have a tweak. You also need to immediately have your car aligned as coilovers when first installed have a dramatic effect on your vehicle's alignment. You will notice an immediate difference with an alignment. Be sure to run 1/16th toe in up front.
Old May 12, 2008 | 07:44 PM
Jay_Sensing's Avatar
It's the toe, I slammed my IS300 and had to drive a good ways to get it aligned. The car would change lanes over a rib in the road. Got it straight and it was good as new.
Old May 13, 2008 | 11:27 PM
J.nguyen's Avatar
Default Re: (Jay_Sensing)
looked at my tires after like literlally only a week of driving, **** is gone... im need to replace them asap & alignment.. well heres a pic of my car though
Damnnn ive beeen busssssyy havnt had time to update this thing, but heres a lil update on my car:
New Stuff as of 05/14/08 :
+ Buddy Club Racing Spec New Coilovers
+ New Front End + Headlights Changed it completely out, no more rock chips & etcs
+ Fenders Rolled
+ OEM Wind Deflector
+ New Tires
+ 2 More Tickets by Cops.. luckily just fix it tickets..
Heres a teaser pic: dont wanna post pics until after Eibach coming up this weekend
Modified by J.nguyen at 11:50 AM 5/14/2008
Old May 14, 2008 | 07:50 AM
fatboi333's Avatar
dang ur car is really low... the geometry on the suspension is f'd up
to save ur tires and help ur suspension get an alignment
i need one too =D
Old May 14, 2008 | 11:50 AM
myek96's Avatar
you have a clean *** ride man
Old May 14, 2008 | 12:42 PM
Default Re: steering loose after coilovers installed (myek96)
it's not that low. He just didn't get an alignment and paid the price of having to get new tires.
ep3brandon
Aug 28, 2009 02:43 PM
Borokazan
Honda Civic (2001 - 2005)
15
Aug 29, 2006 07:49 AM
Ti3d in
Suspension & Brakes
May 18, 2005 09:49 PM
DerangedEG
16
Mar 18, 2004 04:22 AM
Happyman
Mar 4, 2003 06:00 AM
