eg shift linkage???
Old May 9, 2008 | 01:08 PM
95f22a1's Avatar
Default eg shift linkage???
is there some kind of trick to get the pin out? or just really hard?
Old May 9, 2008 | 03:45 PM
1992Si's Avatar
You must mean the bitch pin?
I have found that a long 3/8 extension with a 7/32 allen hex socket on it, feed this down from the top just below/next to the Throttle body, hit it with a big hammer. Oh this works on a D16z6.
Other then that, big hammer and a 7/32 hex bit or punch from the bottom .
When you put it back in leave it so you can remove it easier next time. Or leave it on the tranny and remove it later.
Old May 9, 2008 | 07:08 PM
superfast666's Avatar
Default Re: (1992Si)
an a/c compressor bolt works perfect it already has a point at the end using an extension is bullshit it gets stuck sometimes
Old May 9, 2008 | 08:34 PM
95f22a1's Avatar
already tried with the hex .. socket extention on the top no luck... tried with a punch with a hammer on the bottom it will not move no luck.. whats next..
should i just drill it out? or cut the shift linkage off.... LOL
qustion could it be stuck?
Old May 10, 2008 | 10:58 AM
eskerley's Avatar
Default Re: (95f22a1)
you just have to constantly hit it until it moves a little. It gets really tiring but it will come out. I found if you dont stop hitting it it will start to move but if you stop and start it takes longer. I had the same problem. Use a heavy hammer also.
Old May 17, 2008 | 06:00 AM
hbboy07's Avatar
Default Re: eg shift linkage??? (95f22a1)
There is a special tool you can buy from snap on that goes on an air hammer and pushes it right out that what i use
Old May 17, 2008 | 10:59 PM
evndrkr's Avatar
air punch. i recommend the a/c compressor bolt (as mentioned before), 3lb hammer and testosterone. itll be done before you can say friggin bitchpin.
AViciousTHRUST
Dec 6, 2006 12:11 AM
say_xiong
Sep 21, 2006 11:34 PM
Fuster_Cluck
59
May 25, 2006 08:32 PM
crxhf19
Jan 28, 2005 08:16 PM
MR. MIYAGI
Mar 12, 2004 12:34 PM
