rpm matching while shifting/driving
since i have a lighten flywheel and i don't shift like i'm racing everyday. I was just wondering if anyone else matches rpms before shifting into the next gear. my lighten fly drops the rpms pretty quick while driving so i made it a habit of matching my rpms before in throw it to the next gear. is there a need to do so anyways.
for example i usaully shift around 2.5-3K rpm but when i change gears it drops to like 1-1.5K so the rpm has to jump up around 500-1krpm's or so to get back to speed. i usually tap the gas (barely) in between shifts to keep the rpms in the right revs before i release the clutch.
i think this will save my trans and my motor life. what do you guys think...
i rev match my downshifts during normal everyday driving. keeps me in practice. I've got a stock flywheel on everything at the moment, so I don't have to do it on upshifts.
IMO, it helps the synchro life if you rev match and double clutch anyway, so why not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord »</TD></TR><TR><TD CLASS="quote">Shift faster
hahaha...naw...don't drive like a mad man everyday and i don't try to shift fast. i just driving normal...
</TD></TR></TABLE>hahaha...naw...don't drive like a mad man everyday and i don't try to shift fast. i just driving normal...
I tend to match as well... just getting into the habit before the other motor goes in. Day to day driving I try and be nice to my tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pootie.teng »</TD></TR><TR><TD CLASS="quote">for example i usaully shift around 2.5-3K rpm but when i change gears it drops to like 1-1.5K so the rpm has to jump up around 500-1krpm's or so to get back to speed. i usually tap the gas (barely) in between shifts to keep the rpms in the right revs before i release the clutch.
You do know that it takes as much, if not more fuel to get the car up to speed shifting that low than it would if you shifted a little higher in the powerband, right? Fuel consumption is more dependent on throttle position than it is revs. Try shifting a little higher to keep it from bogging.
I've never had any drivability issues with my 9lb flywheel and I never blip the throttle on an upshift.
Ryan559
Transmission & Drivetrain
Mar 19, 2013 12:14 PM
