2 Loose Wires Hanging Dont Know Where They Go!!! HELP!!!
Ok guys I need your help ASAP
I just recently purchased a 94 EJ1 Coupe, it has SIR layour but was fitted with a D16Z6 engine that the previous owner sent to heaven. So I replaced it with a D15B2 engine & rigged up the 3 Stage Vtec by connecting numer one solenoid on the dizzy ignition wire & the second solenoid on the original vtec wire (works perfect) now I notice there are 2 wires left hanging to the back of the engine they are green with white stripe I beleive & red with yellow stripes, seems they had a connection end which previous owner removed
now I checked autozones website & got a diagram & now I realised my car doesnt have an Air Intake Temp sensor connected or anywhere to be found on the engine.
I used back the D16Z6 intake mani on the D15B2 head along with the D16Z6 exhaust.
Guys I would like to know where these 2 wires are to be connected as I dont see where they go, I connected an Air Temp Sensor to it & it sent the RPM through the roof
Oh my dizzy has to be advanced maximum in order for the car to have power HELP!!
now I checked autozones website & got a diagram & now I realised my car doesnt have an Air Intake Temp sensor connected or anywhere to be found on the engine.I used back the D16Z6 intake mani on the D15B2 head along with the D16Z6 exhaust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wonder squirrel »</TD></TR><TR><TD CLASS="quote">What car and year engine harness do you have? I can check the service manual and see what the two wires lead to.</TD></TR></TABLE>
Maybe you can help me.
I have 2 wires cut also. The one on the bottom where there's a plug. Green/white and yellow/green I believe.
I need to know where it goes to.
A pic would be nice for reference if possible.
*If someone could post a website where I could buy one...that would be fine. Plug/wire and all?*
The year is 1994 & engine harness is the same I believe from the D16Z6 which was in the car when I bought it. Since changed to a D15B2, My O2 sensor is connected, coolant temp sensor, oil pressure/temp sesnsor only sensor I dont see an end for or see is the air temp sensor & when I connect the air temp sensor to these wires the RPM goes through the roof instantly
Ok the colors of the wires are green & white & red & white, they come out of the section of the loom that the O2 sensor wires, water temp, reverse light switch & dizzy wires come from.
I connected my air temp sensor to it yesterday & immediately the car felt & behaved better, only setback was that I could smell the raw gas not beign ignited properly
jdmCivic925
Jul 14, 2006 12:28 PM
xXx Justin xXx
18
May 27, 2003 11:21 AM
