timing belt is loose
Old May 9, 2008 | 07:09 AM
thedao's Avatar
Default timing belt is loose
hey guys i have a b16 and my timing belt is loose on both sides. my question is where is the tensioner located and how tight should i make the belt?????
Old May 9, 2008 | 07:54 AM
jord18's Avatar
Default Re: timing belt is loose (thedao)
its under your driver side engine mount, there should be a rubber cover over it, pull it off, use a 14mm socket, it says to loosen it half a turn but i find if i do that and then go 3 teeth past tdc that its too loose, loosen 1/4 turn go through 1 rotation by turning the bolt inside the crank pulley and just past tdc is should feel nice and tight, then tighten the 14mm to 40 ft/lbs
DONT FORGET ONLY TURN COUNTER CLOCKWISE!!!!
Old May 9, 2008 | 08:47 AM
thedao's Avatar
cool thanx
Mishako129
Sep 4, 2012 10:14 PM
teler86
May 18, 2006 06:29 PM
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
bb4socal
Oct 11, 2005 05:27 PM
spooncivic1
Oct 4, 2004 06:03 PM
