Valve cover filter purpose?
Old May 8, 2008 | 03:00 AM
fryman's Avatar
Default Valve cover filter purpose?
I've seen many racers and tuners that have a small filter on the valve cover instead of having the tube that goes to the air intake.I was wondering whats the purpose for doing that?
Old May 8, 2008 | 04:04 AM
mmuller's Avatar
Mad Scientist
Default Re: Valve cover filter purpose? (fryman)
it does nothing, no pros some cons
Old May 8, 2008 | 04:21 AM
GhostAccord's Avatar
Default Re: Valve cover filter purpose? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fryman &raquo;</TD></TR><TR><TD CLASS="quote">a small filter on the valve cover instead of having the tube that goes to the air intake.</TD></TR></TABLE>
Doesn't do anything more than what you just mentioned. It allows people to run intakes without the VC breather hose. Some after market intakes do not have the fitting for a valve cover breather hose. Or if your running a Turbo you wouldn't usually want too many holes in the intake piping.
Old May 8, 2008 | 04:22 AM
fryman's Avatar
What are the cons?Why do people do it if it has no purpose?
Old May 8, 2008 | 04:25 AM
It does have a purpose, it allows you to maintain the proper fresh air intake for the PVC system. There are no mechanical Pros or cons the only real pro is that it gets rid of one more hose in the engine bay.
Old May 8, 2008 | 04:29 AM
fryman's Avatar
Default Re: Valve cover filter purpose? (GhostAccord)
Oh ok.Didn't see your previous post.Ok now I understand.thanks
Old May 14, 2008 | 06:31 PM
rudebwoy's Avatar
I would say their is a pro.
I run a breather can off the valve cover and also the little filter, lets the engine breathe better instead of having it teed into the catch can, or intake.
Old May 15, 2008 | 12:39 PM
Bakeoff's Avatar
wow...
The pcv system will suck oil vaport back in through the intake. This can gum up the TB, and coat your intake manifold if you're getting a bunch of blow by. Sucking it back into the cylinders makes for a cleaner burning engine, but if you're getting a lot of blow by, you may not know it, and you're running a higher risk of detonation because of the oil. The cons of running a filter? A dirty spot on the bottom of your hood.
Old Mar 28, 2013 | 07:38 AM
firmk20's Avatar
Originally Posted by Bakeoff
wow...
So r u saying its better to run the little filter on the valve cover?
Old Mar 28, 2013 | 06:52 PM
1998GsRIntegra's Avatar
wow...
If you're getting enough blow by from the tiny factory port on the valve cover to foul the combustion mixture, your engine is fucked anyway. If your engine is healthy, there is zero problem with hooking the pcv system up how it was designed to be hooked up by the engineers at honda. Unless you are forced induction, then we are talking about different circumstances.
And wow, old thread.
Old Apr 2, 2013 | 07:23 PM
d_moua's Avatar
there for fresh air into pvc
Old Apr 3, 2013 | 04:12 AM
rudebwoy's Avatar
wow thats a old thread! now that I've been through so many setups since then. Pros would be breathe better, and keep blowby out your intake, Cons would be a messy ingine bay. in the end it is better to get a breather can.
Frost_1097
42
Jan 12, 2007 02:56 PM
italiano23q
11
Feb 8, 2006 05:44 PM
digital sol
Aug 22, 2005 09:47 PM
Prelude91siT
Jan 1, 2004 10:42 AM
fred92htch
Sep 9, 2002 11:35 AM
