Diesel oil in engine
Old May 7, 2008 | 08:02 PM
matmcg's Avatar
Default Diesel oil in engine
So a guy at my work delivering pizzas was out back putting diesel oil mixed with engine oil into the engine (type-r) I asked him what he was doing and he said it would clean the engine up... any one heard of this before? he is a mechanic but just wanna understand wahts going on during this process
Old May 8, 2008 | 12:11 AM
Jimmy's Avatar
Global Moderator
I'm not sure what additives diesel oil has in them..
But i wouldn't recommend running it.
I've heard of people adding a quart of automatic transmission fluid to there engine oil and letting it idle for 5 minutes before an oil change..
To clean engine from any gunk/build up/deposits..
There are also engine flush's and other cleaners that do that also
Old May 8, 2008 | 02:03 AM
SleeperGSR's Avatar
Default Re: (Jimmy)
If this is something you are thinking about doing, i would just get some seafoam and use that instead. I had great luck with that, after using it i removed the valve cover and everything looked new inside. Oil is oil, and using different than recomended probably won't hurt anything, but they probably have a recomended oil for a reason. Good luck
Old May 9, 2008 | 07:10 AM
lmike6453's Avatar
seafoam x2
Old May 9, 2008 | 07:19 AM
sierrahiker8's Avatar
Diesel oil is just a different weight oil with some anti foaming agents in it. I don't think it will hurt anything, but I wouldn't do it.
Old May 9, 2008 | 07:59 AM
Schister66's Avatar
Man U FTW
I've never heard of this; however, i have heard of running #2 diesel through the oiling system for a minute or so in order to clean the system. My Auto tech teacher used to do this to his cars every 30k miles. Its a solvent that gets all of the gunk out of the oiling system. As for diesel oil, i dont see the point.
Old May 9, 2008 | 12:13 PM
I've heard using diesel fuel in oil as well.
Old May 9, 2008 | 01:02 PM
lucky4586's Avatar
Default Re: (sierrahiker8)
It is completely fine to do this as long as there isnt alot of "sludge" in the engine. It could break lose big pieces of oil build up which can get stuck in different parts of the engine if the oil filter doesnt get it first. Just like put any oil cleaning additive in, if anything its better to put "diesel" oil in then additives. I for one do not do this but I keep up with oil changes and use royal purple or ams oil.
Old May 9, 2008 | 05:08 PM
deftonerider's Avatar
don't do it diesel oil is formulated for high high compression motors and it will not like it in your motor
Old May 9, 2008 | 08:40 PM
94GeeSeeR's Avatar
Hahahaha..... My grandfather used to do this to his cars... Worked pretty good.. granted most of his cars were older chevy's and ford's
Never hurt them.. but you only run it for a few minutes.. Just enough to flush the motor
jdm.boi408
Honda CR-V & Element
13
Feb 12, 2011 07:12 PM
jdm.boi408
Feb 8, 2011 07:24 AM
EK45VTi
Aug 11, 2004 03:42 PM
SuperMan19
Nov 5, 2001 03:24 AM
