Compression numbers from my 96 ls...
Old May 7, 2008 | 07:46 PM
xtremsiege2's Avatar
Default Compression numbers from my 96 ls...
Today i was waiting for my dad to get home since he was my helper while bleeding my brakes and decided to run a compression test because i had bought a tester a while back.
Anyway, the engine wasn't up to operating temp, hadnt driven the car in a week and a half but went down the street and stuff so it was some what warm.
The results were.
Cylinder 1-149
cylinder 2-146
cylinder 3-148
cylinder 4-149
cylinder 5-just kidding...
So those low but a nice balance of numbers, is it only low because the engine wasnt really warm at all? Seeing many people at 200 psi makes me nervous. thanks
Old May 7, 2008 | 10:15 PM
TOO MUCH TORQUE's Avatar
those are good numbers for a cold engine. 200 psi are what gsr, b16, type r's get since their high compression/
Old May 7, 2008 | 11:56 PM
Jimmy's Avatar
Global Moderator
The numbers do seem a little low.. but they're all consistent so that's good.
Why did you even do the compression test without the engine at normal operating temperature?
Redo the compression test at normal operating temperature.. and then post #'s.
Old May 9, 2008 | 09:00 AM
Default Re: (Jimmy)
i had time, wasnt really thinking either so i was like, hell with it im doing it. Ill redo tho, thanks
Powered by VTEC
Feb 3, 2008 08:36 PM
wutangben
Jun 2, 2003 06:21 PM
Vanilla4215
Nov 7, 2002 09:46 PM
Doogie Howser
Sep 15, 2002 05:26 PM
Chubz
Jun 27, 2002 02:00 PM
