A/C question..
as i recall, you could use a D-series D-16 bracket to use on a B-series. BUTTTT
a/c will make the motor loose power.
im not to sure if i remembered right, it could be another braket
i've never heard of using a DD-series a/c bracket on a B block.
Hasport is expensive.
only heard of beaing able to use B16 del sol brackets, 99-00 SI (i believe, check this one), or "some" b20 CRV ones (some years had the right ones, not sure which).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20_CRX »</TD></TR><TR><TD CLASS="quote">is there any one that got there a/c going with out upgrading the cross member?</TD></TR></TABLE>
I have an innovative cross member FYI
i'm using the innovative mount. It fits with no issue and i'm using the stock crossmember. The only thing you need the innovative mount is the stock D-series pulley tensioner, it attaches to the mount. Just make sure you get the correct a/c compressor, i forget which it is off the top of my head.
wizzards581
Mar 8, 2004 09:27 PM
